o2 sensor fitting
Old Sep 24, 2005 | 12:44 PM
toyvet1's Avatar
toyvet1
Default o2 sensor fitting
Can anyone tell me what size thread a o2 sensor is . Mine was cross threaded slightly and would like to chase it with a tap to clean it up.
Old Sep 24, 2005 | 02:02 PM
Slalom4me's Avatar
Slalom4me
NTK has two common sizes: M18 (Zirconia sensor style) and
M12 (Titania sensor style)
You don't mention the application but my money is on the M18
being the size you are interested in.
Old Sep 24, 2005 | 03:02 PM
toyvet1's Avatar
toyvet1
Using a AC delco O2 from a 92 350 TPI engine....
Old Sep 24, 2005 | 03:04 PM
TheCorvetteKid's Avatar
TheCorvetteKid
I believe it's M18x1.5.
Old Sep 24, 2005 | 03:33 PM
CFI-EFI's Avatar
CFI-EFI
It IS M18X1.5
RACE ON!!!
Old Sep 24, 2005 | 04:09 PM
toyvet1's Avatar
toyvet1
Is this a size Sears or local store should have or do I need to order one
Old Sep 24, 2005 | 04:44 PM
CFI-EFI's Avatar
CFI-EFI
I don't have my Sears inventory sheets handy, but that used to be a semi common spark plug size. It was fairly often used by Ford. I don't see your location posted below your avatar, so I don't know if you are in a metropolitan area or in the sticks. Industrial supply stores are another source.
RACE ON!!!
Old Sep 24, 2005 | 06:24 PM
toyvet1's Avatar
toyvet1
Great, never even thought of spark plug chaser, Sometimes you overlook the simple By the way Im a suburb of Chicago......
Old Sep 24, 2005 | 06:40 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
RACE ON!!!
That's what it is. Most spark plugs are 14 mm these days but 18 mm used to be very common and that's what the C4s O2s are..
Old Sep 24, 2005 | 07:52 PM
CFI-EFI's Avatar
CFI-EFI
DAMN! You must be big. Do you have your own Zip code? Sorry, I couldn't resist.
I used to live in one of the northern 'burbs.
RACE ON!!!
Old Sep 25, 2005 | 02:25 AM
toyvet1's Avatar
toyvet1
Yes I am on the large side but have not been able to convince the post office to issue me a zip of my own........
Old Sep 25, 2005 | 12:50 PM
toyvet1's Avatar
toyvet1
Great help guys, bought a spark plug chaser and it works like new...
To o2 sensor fitting
