Brake upgrade
Old Sep 25, 2005 | 12:30 AM
severe-1's Avatar
severe-1
Default Brake upgrade
I've changed my 86's 16 inch wheels for AFS's GS 17" rims.
Now that there is some extra room, I would like to add bigger rotors and better calipers. Nothing to crazy, maybe someone elses take off's.
I've looked through many catalogs and have never seen an upgrade kit for an 86 WITH bigger rims. All I've seen is upgrades that fit under the 16's.
When it comes to brakes as with many other things bigger is better.
Anyone know what works with what?
Old Sep 25, 2005 | 12:35 AM
Zix's Avatar
Zix
With the GS wheels you can always go with the C5 brake upgrade option. It's a pretty inexpensive option, usually costs between $500-700 for everything you need.
You can buy a kit from someone, or you can source out the parts on your own (calipers, rotors, pads...). The only non-OEM part you'll need will be the brackets, which I believe forum member Ed Salinas (SP?) has available.
To get an idea of the kit you can go here; http://www.vbandp.com/detail.aspx?ID=291
Old Sep 25, 2005 | 02:51 PM
vader86's Avatar
vader86
I put the GS rims on, then the C5 brakes.
Old Sep 25, 2005 | 10:54 PM
severe-1's Avatar
severe-1
Where did you get your brackets and who makes them?
Old Sep 26, 2005 | 10:24 AM
vader86's Avatar
vader86
forum member 'edsalinas' made them
i'll burn in hell before i pay what Electrodynamics wants for theirs
To Brake upgrade
