lt4 module
Old Sep 25, 2005 | 05:21 PM
bacardioil's Avatar
bacardioil
Default lt4 module
guys
will the lt4 module work on a 93.
Old Sep 25, 2005 | 05:47 PM
STL94LT1's Avatar
STL94LT1
Nope, the LT4 knock module will only work on the 94-96 cars.
Old Sep 25, 2005 | 08:54 PM
bacardioil's Avatar
bacardioil
thanks thats what i thought. is there anything that can be done to make it acted like an lt4 mod.
Old Sep 26, 2005 | 11:59 PM
Mo_Bandy's Avatar
Mo_Bandy
I may be wrong, but you might be able to reprogram the knock attack and decay... to get similar results of the LT4 knock module...
Mo
Old Sep 27, 2005 | 01:10 AM
Baldturbofreak's Avatar
Baldturbofreak
Im pretty sure the module changes the frequency at which the "sensitivity band" is. That is the "note" at which the engine will ring when an event occurs or simply if you whack it with a wrench.
you can program it to not be so agressive with the retard, but the counts will still be there.
On a 93 the spark knock module is near the widshild washer tank, it's a little box. I fyou have a spare to take apart, perhaps the "innards" would be compatible. I wonder exactly what kind of circut it is.??
I will have to do some reasearch, perhaps there is a limited market for such a device.
To lt4 module
