Does Seafoam Work As Advertised?
Old Sep 25, 2005 | 10:11 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Default Does Seafoam Work As Advertised?
Does Seafoam work as advertised? Saw some discussion in C4 General and was wondering what you folks thought...
Old Sep 25, 2005 | 10:16 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Never hoid of it! What the heck's it supposed to do?
Old Sep 25, 2005 | 10:28 PM
USAsOnlyWay's Avatar
USAsOnlyWay
I have a friend who used it in his Saab 900 Turbo, however, I don't think I would use it. He did say it worked however.
If anything I would use Chevron Techron fuel injector cleaner.
Old Sep 25, 2005 | 10:48 PM
okies93's Avatar
okies93
St. Jude Donor 06
i would say it does but.... i used some on a mb190 4cyl gas engine. i followed the instructions on the can. the motor had a miss and was alittle doggish. i started it up and within a few seconds it started smoking real bad and as the motor warmed up it stopped smoking and ran smooth and seemed to have regained some of its lost power. my vette runs great and if it didn't i am not sure i would use it in it. the magic in any can doesn't cure the problem.
Old Sep 25, 2005 | 11:41 PM
85vet's Avatar
85vet
Cruise-In V Veteran
I would not use it in my vette, but I do use it on small engines.
I purchased a snow blower at a swap meet for $10 - owner said it sat for a few years with gas in it and would not start. I dumped out old gas - put new gas in with Seafoam - waited about 15minutes - pulled a few times & it fired up and I ran the whole tank of gas through it. It will clean out Varnish with ease.
Old Sep 26, 2005 | 10:35 AM
rick lambert's Avatar
rick lambert
I've used in on boats-other cars and the vette-I swear by it! the only thing is I don't follow directions on the can-Instead, I put 1/2 in the fuel tank, and the other 1/2 thru a vac line, I never put it in the oil. Keep the RPMs up around 1500-2000 while putting it thru the vac line-it will smoke like hell for a few minutes and may cause an 02 code-it can mist the 02 sensor causing the code-don't worry, it burns off. It has really made a difference for me in the positive sense-AND, it was a visually noticeable difference on the transom of my boat, which really carboned up from trolling.
Old Sep 26, 2005 | 11:55 AM
CMYC4GO's Avatar
CMYC4GO
I swear by it!
Old Sep 26, 2005 | 12:29 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Thanks to all who responded!
Old Sep 26, 2005 | 02:44 PM
aboatguy's Avatar
aboatguy
I used to use it on Carburated engine and it would help clean the carbon out of them!!!
Old Sep 27, 2005 | 01:21 PM
bills1985corvette's Avatar
bills1985corvette
I use Sea Foam and it seems to work great. Also use Deep Creep to clean the TB.
To Does Seafoam Work As Advertised?
