Wtf?
Old Sep 26, 2005 | 12:29 AM
Slipjoint's Avatar
Slipjoint
Default Wtf?
a month ago i bought my 85 - during this time maybe 3 or 4 times it blew a little blue smoke on startup - the worse was this week-in i made a 135 mile run to Reno for a motorcycle event - got there & parked the car Saturday AM - this morning when i went to the parking lot & fired her up for the first time she really blew the smoke? - whats up with this - if it was valve seals wouldn't it do it all the time after setting? - car only has 34,000 mile on it - thanks - t
http://www.picturetrail.com/tomhudson
Old Sep 26, 2005 | 01:25 AM
cv67's Avatar
cv67
St. Jude Donor '05
They have low miles on them, but they are still 20 years old. They get brittle and go bad.
Old Sep 26, 2005 | 12:35 PM
Slipjoint's Avatar
Slipjoint
if they were bad wouldn't they leak down all the time??????
Old Sep 26, 2005 | 01:04 PM
Vetracr's Avatar
Vetracr
Default Leaking valve guides
Its your valve guides. Been there done that.
Larry
Old Sep 26, 2005 | 01:53 PM
dwestsr's Avatar
dwestsr
What you have is classic old brittle valve seals. GM used nitrile rubber on those things and they get very brittle with heat and age and fail to seal the valve stem. As you drive, oil tends to puddle around the springs keepers, and valve stems . When you let it sit, The oil runs down the valve stems and burns when you start it up. For some reason it seems to do this more after a longer run. Also, intakes are worse than exhausts because of the intake vacuum.
I doubt with only 34k on the clock that your valve guides are excessively worn. The only fix for this is to replace the valve seals . I suggest "Viton" or "Teflon" seal material. Also , while you are in there , replace the rocker arms with roller tip rockers. I'm not talking about full roller rockers because they are not as durable for a daily driver. What I'm suggesting are just the roller tips. Those rockers graetly reduce the side loading on the valve guides and make them last a lot longer. There have been waaaay too many Chevy smallblocks rebuilt for excessive oil smoke because of the valve seal / guide wear issue.
The job is fairly easy but aggravating. Depending on your skill level, you will need to decide if you want to tackle it yourself.
Old Sep 26, 2005 | 02:28 PM
Slipjoint's Avatar
Slipjoint
thank you for taking the time to explain the situation - i went out & started it this morning - this is the first time it's been started since the run home yesterday - no smoke - guess i'll let her ride for now & when it gets worse take her down -
Old Sep 26, 2005 | 04:53 PM
FDAMFA's Avatar
FDAMFA
A ounce of cure now is worth more than a pound of damage later. Replace those seals now. If you dont besides the embarrassment of blowing smoke from time to time, you eventually will foul out your plugs and maybe hurt your cats due to the oil consumption. the seals can be replaced without a major tear down using air pressure to keep the valves up when you replace the seals. Probably when you get on it good or let it back down it blows smoke too.
Old Sep 26, 2005 | 09:39 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Since you've had the car, have you changed the oil? Chances are an oil additive like Lucas may have been added and loses it's ability to stop the smoke after a few hundred miles or so. Or the seals are simply giving up as you continue to drive.
Best bet is to replace the seals. Gonna cost about 50-60 bucks in parts and a day in the garage.
Good Luck
Old Sep 26, 2005 | 10:06 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
-Been there ,done that. I used the "rope trick" ,since I did not have a long enough hose ( the story of my life ) to reach the car. Worked great
Old Sep 26, 2005 | 11:45 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
I'll bite - what is the "rope trick"? My 84 blows a little smoke when first started after not driving for a few days. Mileage is about the same - 33K. This sounds like another project for this winter which is less than a month away. This list of winter projects is getting longer.....
Too bad about your short hose!
Old Sep 27, 2005 | 12:09 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Remove all of your spark plugs. Remove the valve covers. You take some poly rope that is a little smaller than the spark plug hole and heat up the end so it gets hard. Stick the end of the rope in the cylinder you want to work on and turn the motor over by hand (use a wrench on one of the top pulley bolts) until the rope is tight between the piston and the valve. This allows you to use a valve spring compressor without having the valve drop into your motor.
Old Sep 27, 2005 | 12:23 AM
MADinAK's Avatar
MADinAK
Sweet. I assume you stuff in as much as you can to fill the chamber....then rotate the piston up.
I'll tackle it when the snow flies. I just changed the valve cover gaskets a month ago. Wish I had noticed the smoke before changing them.
Old Sep 27, 2005 | 12:25 AM
Slipjoint's Avatar
Slipjoint
if a guy had a long hose - he could drive a Vega & be happy
Old Sep 27, 2005 | 10:47 PM
SUNNYD 95's Avatar
SUNNYD 95
I don't think so
To Wtf?
