I upgraded the brakes on my '86 w/ the c5 VBP package. Install went fine and the system does not leak.
I bled the system thoroughly and in the correct order(engine off). I made sure I bled enough fluid out of each line so that all the old fluid was gone.
Problem: While the car is idling, there is little to no resistance in the brake pedal unless I pump it several times. On first couple of pushes it goes straight to the floor. ... master cylinder is full, no leaks.
I have yet to road test it as I fear there is little stopping power.
I would guess maybe a couple of air bubbles stuck in the new calipers, or maybe the seals are a bit worn in the MC, but isn't leaking cause the second seal is catching it. Have you tried tapping the calipers to help dislodge any trapped bubbles?
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yup. And don't forget to bench bleed your new master cylinder. I bought an original replacement m/c from ecklers for $120. Made by PBR australia, best deal by far. When ordering from Ecklers, cross your fingers.
