ARP bolts worth it for engine build?
Old Sep 26, 2005 | 08:45 AM
sothpaw2's Avatar
sothpaw2
Default ARP bolts worth it for engine build?
For Cyl. head bolts and header bolts, to use to re-assemble an engine,
are the ARP bolts the "hot ticket"--good quality, strength, not exorbatant cost?
Or do most just use OEM or some other aftermarket bolt?
Where do most of you get your ARP bolts? Summit?
Old Sep 26, 2005 | 09:24 AM
MYCoupe's Avatar
MYCoupe
For the head bolts I would definitely go with the ARP ones. Header bolts you have more choices, but again can't go wrong with the ARP ones unless you want to get some of the "locking" type bolts.
Summit always has pretty competitive prices and their service has always been good (at least for me).
Old Sep 26, 2005 | 10:08 AM
neat's Avatar
neat
ARP bolts are the way to go IMO. Especially for high stress applications. Heads, mains, rods, etc...
Old Sep 26, 2005 | 11:30 AM
CFI-EFI's Avatar
CFI-EFI
I consider the ARP bolts a MUST for the rods, and highly desirable for the mains and heads. I consider them purely optional and possibly a waste of money in most other locations. After all, what is the point of using a 170,000# to 190,000# tensile strength bolt to hold your headers on to aluminum heads?
RACE ON!!!
Old Sep 26, 2005 | 11:48 AM
scorp508's Avatar
scorp508
ARP fasterners are a must. I also use their lubricant (although the girls kinda get pissed at that, not sure why.....) and make sure you go by their torque specifications.
Old Sep 26, 2005 | 11:53 AM
Red Tornado's Avatar
Red Tornado
i agree, i insisted on ARP studs for the mains, and the bolts for the rods and cylinder heads.
Old Sep 26, 2005 | 11:57 AM
scorp508's Avatar
scorp508
Also.... most can't grasp this concept, but if you want a "more perfect" torque reading then use their 12-point fasterners if you have a set of 12-point sockets.
Old Sep 26, 2005 | 12:23 PM
Morley's Avatar
Morley
Makes no difference how many "points" are on the fasteners, torque is torque. If 12 point fasteners were that superior, we'd be using them all over our $50,000,000 + private jets. 12 point just gets you a smaller base to the head or nut.
Old Sep 26, 2005 | 12:27 PM
scorp508's Avatar
scorp508
Incorrect. A 12-point fastener has more contact with the socket used to tighten it, which in turn makes torquing proceedures more accurate. It also aids in the prevention stripping of stuck fasteners.
Old Sep 26, 2005 | 12:39 PM
Morley's Avatar
Morley
Going to have to disagree here. Having been an A&P mechanic for 25+ years I can tell you there is no difference between torquing a 6 or 12 point fastener. The socket/wrench either contacts the fastener or it doesn't, the torque wrench doesn't care how many "points" are on it.
Old Sep 26, 2005 | 01:16 PM
VB Black Ice's Avatar
VB Black Ice
Headers: Stage 8 Locking Fasteners. Trust me, no header leaks will be found when these are used right...
Old Sep 26, 2005 | 01:27 PM
scorp508's Avatar
scorp508
Thats fine if you'd like to.
scorp508's Avatar
scorp508
That is pretty much the key for any header fastener. Most people do not go back and retighten the fasterners like they should after some heating cycles.
Old Sep 26, 2005 | 02:09 PM
sothpaw2's Avatar
sothpaw2
Who makes 'em? Where do you get 'em?
Assume that no one would just re-use the stock header bolts, even though they are into aluminum (LT1) heads (as CFI points out--thanks).
Old Sep 26, 2005 | 02:18 PM
Red Tornado
i got my fancy stage 8's from summitracing. they never budged
Old Sep 26, 2005 | 02:19 PM
CFI-EFI's Avatar
CFI-EFI
The key words being, "when these are used right". This is also true of a set of $10.00, Summit or Mr. Gasket bolts as well as those pricey Stage 8 bolts.
RACE ON!!!
Old Sep 26, 2005 | 05:19 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Also used them for my flexplate.
To ARP bolts worth it for engine build?
