Auto trani won’t shift from 3rd to 4th gear.
Old Sep 26, 2005 | 04:54 PM
vettef6's Avatar
vettef6
Default Auto trani won’t shift from 3rd to 4th gear.
[/B]Does anyone have an idea why my 1 ½ year old 700R4 Raptor trani won't shift into fourth?? There is enough oil in it and it doesn't smell either. Furthermore I took out the 3-4 shift valve and checked it out, but couldn't find anything. The manual says the governor might be a cause for no 4th gear shift.
I would appreciate any help in this matter
Old Sep 26, 2005 | 05:52 PM
Pete K's Avatar
Pete K
I would bet it is in the valve body. Most governor problems are related to the 1/2 shift. I would remove the governor, clean and check it for free movement. Then I would inspect and relace, if nescessary the gear. They are known to applecore. If this failed, I would drop the valve body and persue it.
