speedbleeder
Old Sep 26, 2005 | 09:34 PM
mike t's Avatar
mike t
Default speedbleeder
I used the speedbleeder in my 95 VR4 in the past with no problems so assumed there would be no problems with my 95 vett. It was not so. From some reason they would not seat and except for one they all leaked. I did set them to torque specs. I had to put the old ones back and no problem. I did go the speedbleeder.com for these and the designated part number was SB1010 but perhaps this should have been SB1010SS. Anybody have issue with these speedbleeders. Thank you
Old Sep 27, 2005 | 07:34 AM
jwt1603's Avatar
jwt1603
I have them and use them a lot to bleed and flush the system with no problems.
Old Sep 27, 2005 | 07:59 AM
runner140*'s Avatar
runner140*
Been using them for five or six months now without any problems.
Old Sep 27, 2005 | 10:46 AM
MYCoupe's Avatar
MYCoupe
I've had them on my car for over a year with no problems. I think the difference in the part numbers that you listed is that one appears to be stainless steel while the other one is not. By the way I went with the stainless steel ones. They were more money, but I figured they would last I wouldn't have to worry about corrosion.
Old Sep 27, 2005 | 09:43 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Have them on '89 now for about two months, and everything is great. I also got the SB1010SS (stainless steel) version, primarily for the corrosion resistance factor.
I think you may have just gotten a set that wasn't machined properly. You may want to either send the company a quick email or call them and let them know what's happened. They seem like stand-up people - I'm sure they will rectify the situation.
Good luck with it.
Old Sep 27, 2005 | 10:01 PM
mike t's Avatar
mike t
Good idea I will call, I think you may be right. On close examination of the tips it seemed contact was not fully made when seated. Thank you.
Old Sep 27, 2005 | 10:43 PM
Red Tornado's Avatar
Red Tornado
i might get these as well. is the thread sealant necessary? $10 for alot of that stuff appears to be overkill. In fact, the idea of using sealant at all sounds a bit scary. Anyone use that sealant?
Old Sep 27, 2005 | 11:17 PM
rrubel's Avatar
rrubel
They come with sealant to begin with; you only need to add more if you loosen them a lot.
I had to torque them down tighter (not much) than recommended spec because I had small leaks, but otherwise they work great.
[RICHR]
MYCoupe's Avatar
MYCoupe
I didn't use any sealant on mine. A year later and still no leaks and I've bled my brakes a couple of times since intalling them.
Old Sep 27, 2005 | 11:28 PM
Red Tornado
thanks guys. $60 (ss) seems like a productive investment, i'm enamored with the prospect of a one-man operation, with such ease, which will entice me to bleed them once a year for good maintenance practices
Old Sep 28, 2005 | 02:03 AM
Aussie Vet's Avatar
Aussie Vet
got them also and all but one leaked, but only very slightly, just tightened them a bit tighter and all is now good.
Old Sep 28, 2005 | 10:15 AM
luvmy92's Avatar
luvmy92
I have been told to remove the sealant on them and replace with the white teflon tape. I say this because I am getting ready to install mine on the Wilwoods. Can anyone remark on that?
Thanks,
Mike
Old Sep 28, 2005 | 07:54 PM
TheCorvetteKid
Thanks,
Mike
Never heard that one before. The ones from Speedbleeder.com come with the proper amount of sealant already on the threads. I've heard that the less-expensive Russell versions actually come with TOO much thread sealant on them.
IMHO, I wouldn't bother with the teflon tape. But I would spend the money and get the stainless steel versions - especially on an expesive set of Wilwood calipers!
Old Sep 29, 2005 | 08:58 AM
luvmy92's Avatar
luvmy92
Yep! Got the SS ones... cost $120 for 8 of 'em. The Wilwoods have 2 bleed screws per caliper, so it's double, which sucks!
Looking forward to getting them on and trying them out tho. I will just leave 'em alone and install them as advertised.
Thanks for the reply.
Mike
Old Sep 29, 2005 | 12:47 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Mine would not seat because of the excessive sealant. The sealant also would flake off and get into the caliper and into the bleed port.
That sealant does do anything to seal the brake system, it's only intended to prevent air from being drawn in during bleeding.
I removed all the sealant with a thread die, and used teflon tape instead. Works great, no more fighting the bleeders.
Old Sep 29, 2005 | 12:51 PM
CentralCoaster
You'll notice when bleeding the Wilwoods, that the inner caliper half moves more fluid, and doesn't let the outer one bleed well, so bleed with both open, then close the inner one, and bleed some more. Although it's not necessary with speedbleeders, I hooked up hoses and ran them up then back down to a bottle, so I could see the air bubbles from inside the car, didn't want to waste my wilwood brake fluid.
Old Sep 29, 2005 | 01:49 PM
luvmy92's Avatar
luvmy92
Are you using the same speed bleeder as I... the SS ones?
Mike
Old Sep 29, 2005 | 01:52 PM
luvmy92's Avatar
luvmy92
I think I do have dual bleeder hoses... is that how you did it? So basically open them both up and pump a few times, and then close the inner and pump a few more on just the outer.
The first go round I will be doing a complete flush from ATE blue to ATE gold.
Mike
To speedbleeder
