My 3-4 WOT shift observation
Old Sep 27, 2005 | 12:31 AM
kopbet89c4's Avatar
kopbet89c4
Default My 3-4 WOT shift observation
I see some people are concerned about thinking 3rd gear won't ever shift to OD, even if you are taching the 5500 rpm redline. First off, it will take a while to get to 136 mph if you are 100% stock. Secondly, it will only shift to 4 on WOT if your car originally came with the 3.07s. If a person had 2.59s and slapped on 3.07s, that may be the reason that the 3-4 wasn't shifting because in a 2.59 car, you'd reach the top speed on 3rd gear, 155 mph @ 5300 rpms. Even if you could push it faster way past 5500 rpms, it still wouldn't shift because the OD + 2.59 gear makes the next gear out of the power band. I'm glad my Vette finally shifted to OD without letting go of the throttle after passing 136 mph. Each time I went faster than 136 mph, I'd have to let go of the throttle for it to shift to OD because I was afraid of seeing 5500 rpms for more than a couple seconds. Yes, it will seem like your car is pegged at redline for awhile but if your car had 3.07s from the factory, it should shift. God that was fun but I still had to test and see if I indeed have my 3-4 shift at WOT.
Old Sep 27, 2005 | 10:38 AM
CFI-EFI's Avatar
CFI-EFI
That is nuts! The gear ratio spread in the 700R4 and it's derivatives doesn't change with the rear axle ratio. The rpm drop when shifting from 3rd to 4th at 5500 rpms is the same whether the rear is a 2.59, a 3.07, or even a 4.11. You will be no more, in or out, of the "power band", because of the rear axle ratio.
RACE ON!!!
Old Sep 27, 2005 | 11:11 AM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
when mine had 2.59's it would shift to 4th at WOT. I'm thinking you need to do some more research. As for what CFI-EFI said -
Next.....
Old Sep 27, 2005 | 11:37 AM
87 rag's Avatar
87 rag
Is this speed accurate?
Do you need to be doing 135 plus mph to get the shift into 4th?
I have 3.07s and my car seems to run out of steam or out of road before it will shift (about 130 mph). If i back off on the throttle it will shift right away.
Old Sep 27, 2005 | 11:42 AM
kopbet89c4's Avatar
kopbet89c4
I would think that stock 2.59 cars top out in 3rd, right?? So if you take your foot of the gas, THEN you'd shift to OD and hope to have enough power to pull OD + a 2.59 gear. Looks like 3.07 cars use all of their gears with the the L98s stock power to the top speed. Just the 3-4th shift will take awhile. Now if only I can take my car to 195 mph @ 5500 rpms...
Old Sep 27, 2005 | 12:22 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
Mine would pull 4th all the way over 150 without a problem. Now with the 3.73's if left in OD she will shift into 4th at 85mph and pull it to 140.
Again, same trans as it had in it with the 2.59's. Shifts at WOT just fine. But if I put her in D she will pull 3rd to about 115 then I shift it to 4th and she will run to 140.
When I drag, I run her in 3rd (D) and she runs 12.4's at 114mph.
It has never had a problem pulling 4th in or out of stock form.
Not sure where you are getting your info, but it's wrong.
Old Sep 27, 2005 | 04:51 PM
87 rag's Avatar
87 rag
Does anyone know what speed an L98 with 3.07s should shift from 3rd to 4th at WOT?
Old Sep 27, 2005 | 06:39 PM
Pete K's Avatar
Pete K
At Pocono Raceway, my car would make the 3-4 shift(under wot) at approx 127 mph.
Old Sep 27, 2005 | 08:20 PM
87 rag's Avatar
87 rag
Is that stock and with 3.07s?
Old Sep 27, 2005 | 09:03 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
knock yourself out:
Code:
Transmission Ratios:
   1st: 3.06 2nd: 1.63 3rd: 1 4th: 0.7
Tire Diameter 1: 26 inches
Rear Gear Ratio 1: 3.07:1
MPH
RPM 1st 2nd 3rd 4th 5th 6th
1000 8 15 24 35 0 0
1500 12 22 36 52 0 0
2000 16 30 48 69 0 0
2500 20 37 60 86 0 0
3000 24 45 73 104 0 0
3500 28 52 85 121 0 0
4000 32 59 97 138 0 0
4500 36 67 109 155 0 0
5000 40 74 121 173 0 0
5500 43 82 133 190 0 0
6000 47 89 145 207 0 0
6500 51 96 157 225 0 0
7000 55 104 169 242 0 0
7500 59 111 181 259 0 0
8000 63 119 194 276 0 0
Tire Diameter 2: 26 inches
Rear Gear Ratio 2: 2.59:1
MPH
1000  9 18 29 41 0 0
1500  14 26 43 61 0 0
2000  19 35 57 82 0 0
2500  23 44 72 102 0 0
3000  28 53 86 123 0 0
3500  33 62 100 143 0 0
4000  37 70 115 164 0 0
4500  42 79 129 184 0 0
5000  47 88 143 205 0 0
5500  52 97 158 225 0 0
6000  56 106 172 246 0 0
6500  61 114 186 266 0 0
7000  66 123 201 287 0 0
7500  70 132 215 307 0 0
8000  75 141 229 328 0 0
Old Sep 27, 2005 | 10:15 PM
Pete K's Avatar
Pete K
Originally Posted by 87 rag
yes
Old Sep 28, 2005 | 08:10 AM
87 rag's Avatar
87 rag
Thanks Pete. Thanks Ski.
Old Sep 28, 2005 | 10:57 AM
nxs055's Avatar
nxs055
Cruising
mine shifts to 4th at 132.
thats with stock 3.07's in an 89....
it is scarry to get it to shift to 4th though, cuz it hangs at redline for what feels like forever
Old Sep 28, 2005 | 11:51 AM
87 rag's Avatar
87 rag
I think this is what is going on with mine.
I don't wait that couple of extra seconds for it to shift.
Old Sep 29, 2005 | 10:09 PM
Lichen's Avatar
Lichen
If you just barely touch the brake pedal (just enough to flash the brake lights), it should shift into OD
Old Sep 29, 2005 | 10:57 PM
MrNuke's Avatar
MrNuke
Mine used to shift at WOT to 4th at about 120-125mph.
Now I max out 3rd at about 115.. (3.45 gears)
Old Sep 30, 2005 | 01:46 AM
Mo_Bandy's Avatar
Mo_Bandy
Tapping the rev limiter on the dyno I was at about 134 in 3rd gear ( 5800 rpm) ...
Mo
To My 3-4 WOT shift observation
