Check Engine Soon
Old Sep 27, 2005 | 07:54 AM
kalister1's Avatar
kalister1
Default Check Engine Soon
My "Check Engine Soon" light comes on only in the rain. Oxegen sensor is doing it. Could the rain be bringing exhaust temp down, causing this?
Old Sep 27, 2005 | 09:57 AM
CFI-EFI's Avatar
CFI-EFI
NO! If the temp of the O2 drops below approx 600°F, the information sent from the O2 to the ECM will be meaningless, and the ECM will drop out of closed loop to open loop, but that won't cause a check engine light. Start trouble shooting. There may be a water aggravated short in a wire somewhere. Don't shoot the messenger. A fault code sent by the O2 sensor (or any other sensor) doesn't necessarily mean the sensor is the cause.
RACE ON!!!
Old Sep 27, 2005 | 10:08 AM
vader86's Avatar
vader86
No, you have a code, you must pull it.
Dont start wildly guessing.
Old Sep 27, 2005 | 11:08 AM
kalister1's Avatar
kalister1
I think this car uses 2 Oxegen sensors? 93 LT1. If so, do you always replace in pairs?
Old Sep 27, 2005 | 11:16 AM
CFI-EFI's Avatar
CFI-EFI
Read or reread, as applicable.
RACE ON!!!
PS. O2 sensors are waterproof.
To Check Engine Soon
