C-5 brake upgrade install question.
Old Sep 28, 2005 | 10:41 PM
Dartvader's Avatar
Dartvader
Default C-5 brake upgrade install question.
I have most of the parts now in hand for the c-5 front brake upgrade. I have GM rotors, z06 calipers and pads, and am waiting for the stainless steel flex hoses from Big Brakes, one of our sponsers. I thought Chris at Superior Chevrolet was a big help, as was Kevin at Big Brakes. They were both real gentlemen. The question is, can I simply look at the assembly of the c-4 brakes and tell how the c-5 brakes go together? The rule of thumb with brakes is take apart only one side at a time so you have one side still together to examine when you cannot remember where the little "do-hicky" goes. But in this case, with different parts, how similar are they? Can anyone who has done this upgrade alert me to considerations here? Also, how about the bleeding issue. Can I bleed the system satisfactorily with my vacuum pump? I have a 95 coupe which has ASR and ABS. Thanks in advance for any tips.
Old Sep 28, 2005 | 10:59 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
You are going to love how the brakes work.
Installing them will be a piece of cake for you. Do one side at a time.
Not many things to confuse. Just take your time.
Make sure you support the car well. You do not want to do any mods to your head!
Bleed them like you have bled them in the past.
Good luck and let us know how they turn out. Post some before and after pics if you can.
Save The Wave!
Old Sep 29, 2005 | 12:14 AM
Dartvader's Avatar
Dartvader
Hey Man!; thanks for the tips, and thanks for the confidence building positive thoughts. ..I figured they could not be too difficult since I read about guys who change their brakes on race day, and then go back to street brakes afterwards. I have never bled the Corvette brakes though. I have bled many other systems, many times. I am told I need a techII machine. Is this just dealer BS? I have always used a Mity Vac pump, and just drawn on the open bleeder until it runs clear. Is there an order to the wheels that is best? How about the bleed valve on the ABS pump? Should I bleed that first?
Old Sep 29, 2005 | 01:36 AM
vader86's Avatar
vader86
They go on like any other brakes, just put the adapter on right.
Old Sep 29, 2005 | 09:28 AM
WNDOPDLR's Avatar
WNDOPDLR
It really is very straightforward and simple. I might suggest that you mount the adaptor brackets to the spindel with red locktight as a safety measure. I used my mighty-vac to bleed my C4 brakes all the time. Nothing special there. Start at the passenger rear, driver rear, passenger front and lastly driver front.
Old Sep 29, 2005 | 10:12 AM
TorchRedlt4man
I do not think I would even touch the ABS pump. The fluid is pulled thru that anyway. At least that is what I have been told.
Again: take your time and you will end up with one HOT set-up!
Save The Wave!
Old Sep 29, 2005 | 03:19 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Here
To C-5 brake upgrade install question.
