were to look know?? idle problem
than i checked most of the vacuum ports and got by my gauge in the normal, green which is betwwen 18 and 22 inch Hg.
but shes still idleing kind of crappy?????
when i got the vette 4 moths ago, it had a whole new exhaust system put on, not sure about O2 sensor so thats on the way. i changed the plugs, cap, rotor, remove TB and cleaned it, clean IAC, re-set TPS and low idle like the GM manual said. it failed a emissions test at a idle for high hydrocarbons. i did another code scan and nothing is showing up but the code 12 the system is working.
any idea were to check next. bad wires?
Use the ECM's Field Test mode, described on my site, to see if it's going into and staying in closed loop.
If it's missing at idle clip a timing light onto each plug wire to see if misses coincide with missed flashes on a wire.
To test for a fuel system leak, just turn the key on for a few seconds and record the pressure changes vs time. It should hold very close to that 44 psi value for a few minutes, with a slow drop off.
so i should have high fuel presure then 44psi while its running? how long should it hold presure after shut off? right now it goes from 39psi running to 22psi right at shut off almost right away. then each drop of psi to about 16psi is each about 10 minutes apart.
ohm check the injectors, i hope thats in the service manual?
i did do a code scan again with my code reader, and only getting the code 12. isn't that telling me the ECM is working o.k.?? i will do it again to check the speed of the 12 flashes.
i have been running fuel injector cleaner and its not doing the long start when warm deal either, not that it did it alot at first.
i have a new O2 sensor coming, and i have a cooant temp senosr ready to go in, i am going to do them and see what hapens too. and recheck with my fuel pressure tester. why dose the book say 34psi to 39psi is right if it should be 44psi. now when i disconnected the vacuum line to the FPR i got 44psi. i am still wondering if i missing some thing with all the vacuum lines or not have them right??? last owner had most of them disconnected, like nothing going to the FPR.. the sticker on the rad it kind of hard to read on my 86. and body got some good pictures of the aft right intake and how the egr is suppose to be hooked up!!
thanks guys!!!
my aux fan comes on when the dash gauge reads 170 temp wise, could that be making the engine run to cold? last night i was driving around town temp was reading 168, only a cool night here in maryland.
any pictures would be great!!
High CO2 indicates a rich mixture. Look for vacuum leaks. If air is entering either the intake or the exhaust system, it could cause the O2 sensor to read lean, making the ECM add fuel to correct the problem. Another test would be to pull the vacuum hose off of the EGR valve, plug it, and observe the idle quality.
I hate to see you throwing money at it by replacing the O2 and the CTS, without them having tested as failed.
RACE ON!!!
https://www.corvetteforum.com/techti...=192&TopicID=2
You should make fuel pressure measurements with the vacuum line disconnected from the FPR and plugged.
If pressure is dropping immediately by 10psi or so, you have a fuel system leak. Removing the gas cap door & rubber boot and clamp the feed & return lines in turn and power the fuel pump:
-If pressure does not drop with the feed line clamped the problem is with the check valve in the pump.
-If pressure does not drop with the return line clamped the problem is with the FPR.
-If pressure drops with both lines clamped the problem is with a leaking injector; you should pull the set (all 9) and send them to Rich at Cruzinpeformance (link on my site) for cleaning, flow testing and leak testing.
If you would like a pic of vacuum tube routing schematic send me an e-mail at jgkov@msn.com and I'll return the pic.
the FPR vacuum lines was plugged off when i got the vette, i wonder if that was to hide the fact he knew it was bad? because i did check the FP with that plugged and it went to 44psi from the 39psi i was getting.
if my fuel pressure is 39psi at a idle what should it jump too when i hit the throttle??
i am still not sure i have vacuum line hooked up right??
Your PCV system sounds good as far as you've explained it. You need a filtered inlet, the breather(?), and a vacuum source hooked up to the PCV valve in the opposite valve cover, exhausting the crankcase fumes to the inlet system so they can be burned with the air fuel mixture.
RACE ON!!!
any body with pictures of the right and left side of engine value covers and vacuum lines?
RACE ON!!!
