washer size for frisbee removal?
Old Oct 2, 2005 | 08:16 PM
SDS Photography's Avatar
SDS Photography
Default washer size for frisbee removal?
anyone know the size washer needed to compensate for the removal?
Old Oct 2, 2005 | 08:37 PM
mseven's Avatar
mseven
I used a regular steel lockwasher for the bolt size. If you look at it you can the thickness is the same and you can also look at the back side of the pulley to see how close it is, before and after, use some blue locktite on it just in case
Old Oct 3, 2005 | 12:28 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm pretty sure it's 5/16" if memory serves. Either 2 flats with a lock nut or a flat and lockwasher with a standard nut will be fine.
To washer size for frisbee removal?
