Question..... Whose headers work best with AFR Heads?
Heads = AFR 190 (SHVR) Small chamber, heat riser, Vette plugs (angle) bored to 195cc.
With current set of headers (MFG unknown) wires 1 & 7 rub on the boots.
Thanks.....
I ran the LPE 1 3/4" long tubes without any problems either. You may just have an oddball header on your hands. For some reason I think the heddman's may not fit (the $150 set from summit) but other than that I have never heard of clearance problems with the correct vette angle plug heads.
You can still have some boot clarence issues with afr heads and tpis headers. I have to use boot protectors on #6 and especially on #7. It is an easily corrected item.
