TunerProRT Problems
Old Oct 3, 2005 | 06:07 PM
90Indy's Avatar
90Indy
Default TunerProRT Problems
I have been trying to datalog using TunerProRT software. I have never used this software or datalogged before. I have been able to burn a prom using a bin file from pcmforless and have driven the car with the prom installed. I now need to datalog while driving with this prom installed. I can not get the software to show the ALDL is connected although I have the autoprom connected to the car and I can read the prom that is installed.
Do I need to load something into TunerPro? I will say that when I have the Fastburn program running and start TunerPro I can get to nothing in TunerPro. If I first start TunerPro and then start Fastburn I can get to nothing in Fastburn. Maybe this is normal and I am trying to make something happen that doesn't need to happen. By the way when I say starting a program I mean double clicking on the desktop shortcut.
I appreciate your bearing with me as I don't have a clue as to what I am doing at this point. I was just happy to have figured out how to burn a prom.
90Indy
Old Oct 18, 2005 | 12:06 PM
1992B4C's Avatar
1992B4C
I tried the same thing. Ended up needing Datamaster to log.
Check out the following thread I made:
http://thirdgen.org/techbb2/showthre...hreadid=262214
Old Oct 18, 2005 | 01:28 PM
90Indy's Avatar
90Indy
I am really confused now. It sounds to me as though the TunerProRT I purchased from Moates will not work unless I remove certain sectors from the data stream. I thought this soft/hardware was basically plug and play and the major gremlins had been removed.
I will contact Moates and see what he has to say.
By the way, when you purchased TTS Datamaster did you have to purchase their cable or could you use what you got from Moates?
Thanks for the reply.
90Indy
To TunerProRT Problems
