Back up lights
Old Oct 3, 2005 | 08:07 PM
JD JOHNSON's Avatar
JD JOHNSON
Default Back up lights
First of all..........Been awhile, hope everyone is doing well.......... My backup lights are not working..It's on the same fuse as the shift from 1st to 4th which is a 15 amp. The fuse seems to be ok...Any ideas!!!! THANKS
Old Oct 3, 2005 | 08:28 PM
JD JOHNSON's Avatar
JD JOHNSON
Default Tough one uh..
I guess I'll go over to C4 General,,,,maybe they can help
Old Oct 3, 2005 | 08:45 PM
sonomacrew01's Avatar
sonomacrew01
I have the same problem... its the switch on the tranny. PITA. I'm replacing mine when I replace the clutch
Old Oct 3, 2005 | 09:04 PM
LD85's Avatar
LD85
On my 4+3 it was a switch on the tranny that went bad
Old Oct 3, 2005 | 10:41 PM
TheCorvetteKid's Avatar
TheCorvetteKid
This is a common problem.
A mechanic once told me that just cleaning the switch can solve the issue. But, for the effort to take the switch off in order to clean it, you might as well just replace it.
Good luck
Old Oct 4, 2005 | 07:34 AM
87vette's Avatar
87vette
I had my a new rebuilt tranny put into my vette at the dealer and a few months later I noticed the backup lights weren't working. i took it to the dealer under warranty and it wasnt the switch on my tranny. I later found out when I was under the car that a wire was spliced in half by a mouse. I taped it back together and the lights now work.
Old Oct 4, 2005 | 02:55 PM
JD JOHNSON's Avatar
JD JOHNSON
Thanks!! For all the threads..I'LL CHECK OUT WHAT EVERYONE SAID AND LET YOU KNOW WHAT I FOUND OUT.... THANKS AGAIN
To Back up lights
