LT4 horsepower
The Grand Sport Registry has dyno runs from unmodified cars that peak at over 300 rwh.
(in effect) Dyno tests of 125 LT4s resulted in the following stats (credited to by Stan Adelman of Auto Performance Test Lab in Atlanta, GA.):
Less than 25% of (LT4s) dynoed <345hp,
about 15% fell into the 360 to 375hp range,
about 10% between 375 and 385hp,
2% hit low 390s hp
If I do the math, that means 48% must be in the gap between 345 and 360 hp (the article said average is between 350 and 360hp)
I'm told that every dyno is different, so getting an absolute reading comparision is difficult between machines. But, relative comparisions on the same machine are accurate to a much greater degree. A grain of salt is possibly in order here as well.
Hope this helps.
P.
bone stock to the air filter and mufflers i pulled 306.1 RWHP / 308.2 RWTQ.....
and it was a hot day and a hot engine
thats 360 CHP and 363 CTQ
Now after welding straight pipes in the place of mufflers and resonator, and a cut airlid- still stock filter, i think i should be in the 316RWHP range which is 372 CHP
Long tubes and high flows should buy me 12-18 RWHP
a LT4hot cam with 1.7RR's should buy me 20-30 RWHP
a DYNO tune should buy me another 10-20 RWHP
so in the end i will be looking in the worst case 360RWHP and best best case 385 RWHP
--Kevin
P.
P.
Car was a lot faster when I lived in Cali. Had to mod the crap out of it when I moved it here, because it felt like a different car.
I'm trying to figure out zakly whicha-way to go w/ my 450-475 hp goal for m LT1, keeping in mind I may be back in Colorado again, living at 8500+ feet. It would prolly take all of a 383, LT headers, and cam just to get back to where I am now at 600 ft AMSL w/ the LT1!
Much as I would rather avoid FI and associated complexities, a SC would offer an immediate hp lift, and I could do the lower end in a year or so. That might be a way to solve the thin air problem.
I'm not making a point...Just sorta thinking out loud, I guess!
P.
On my dyno, it stated "CF: SAE Smoothing" Is this different than what it states on other dyno sheets?
The LT-1s are great, but the LT-4s are basicly the same as the LT-1s, the LT-4 is simply already factory upgraded in some areas.
That thing must have been built on a wednesday
