LT-1 ignition experts
Old Oct 4, 2005 | 09:55 AM
loflite's Avatar
loflite
Default LT-1 ignition experts
My '95 auto has started to miss intermittently. It will be running fine and just like a switch was pulled, it starts to miss badly. It will miss for a few miles and then just as quickly stop. It's starting to miss more and more. My guess is ignition. Gas would be more of a constant thing. Any thoughts? Thanks.
Old Oct 4, 2005 | 10:11 AM
Tom Piper's Avatar
Tom Piper
Opti-Spark???
Tom Piper
Old Oct 4, 2005 | 10:51 AM
USCG's Avatar
USCG
I have a 96 stock LT1 auto 115k and mine is starting to miss also, but only for a second or two. You're probably ahead of me on the trail, so I would be interested in learning the cause and solution. The few times mine misses seems to be when I lightly get back on the throttle, like after coasting a bit then attempting to maintain speed.
My first reaction is "Opti" based on all the horror stories on the forum, but we have the improved Opti, and any distributor that goes over 100k without maintenance can't be all that bad!
Also, I don't have any violent reaction when the miss comes and goes; meaning with a carb'd car, a miss in the ingnition gives you a jerking reaction when the unburned gas is re-ignited. The smooth reaction of my miss makes me think it might be related to the injectors and/or computer grounds.
I'm also wondering if it might be vacuum related since I don't seem to feel it under steady throttle.
Keep us posted and l personally would like to know how it turns out.
Old Oct 4, 2005 | 10:54 AM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Sounds like opti to me also. For a LOT of info on this topic...do a search. Good luck.
Old Oct 5, 2005 | 02:09 AM
Mo_Bandy's Avatar
Mo_Bandy
prolly opti...
It will get to a pont if you romp on it it will have a high speed miss and then you'll probably get a code stating that hi or lo resolution error...
That had been my experience...
Mo
Old Oct 5, 2005 | 08:04 AM
runner140*'s Avatar
runner140*
Optispark would be the last try. First I would try new plugs and wires if they havn't been changed in some time.
Old Oct 5, 2005 | 09:07 AM
LT4-Z51's Avatar
LT4-Z51
Pull a spark plug from each side see if one side is running richer than the other.I just went through the same thing & everyone said optispark.So before I spent alot of money on the opti I went & had the car diagnostically tested for 60.00.Problem had nothing to do with opti , it was a 50.00 oxygen senser & took 5 min. to change not 9 or 10 hours.Mine pulled a lean code & a multiple cylinder missfire code.GOOD LUCK
Old Oct 5, 2005 | 09:28 AM
cicch95's Avatar
cicch95
I would say this is a given. Never tear down a car without knowing the codes, causing the problem.
Old Oct 5, 2005 | 10:25 AM
bogus's Avatar
bogus
I am not so convinced the miss is caused by the opti. If it was an opti related miss, it would be associated with a wondering idle and be isolated to an higher RPM. Also, the miss would be consistant.
My guess? A bad fuel filter or the coil wire is grounding to the engine/waterpump.
Old Oct 5, 2005 | 11:13 AM
RacerX70CC's Avatar
RacerX70CC
Anything over 50,000 on the odometer, replace the wires and Opti cap/rotor. The Opti is most likely just fine, but the cap and rotor do wear out.
Old Oct 6, 2005 | 11:26 PM
loflite's Avatar
loflite
Okay, I assumed it was bad gas and put injector cleaner in the tank, fresh gas, and new fuel filter and drove about 100 miles. Still misses badly but now have a bad knock on the front end of the engine at low idle. Any ideas? No codes.
Old Oct 7, 2005 | 09:25 AM
loflite's Avatar
loflite
anymore ideas?
Old Oct 7, 2005 | 10:43 AM
LT4-Z51's Avatar
LT4-Z51
Quite being stubborn & go have it diagnosed or spend 1500.00 dollers replacing this part then that part just to find out that each part doesn't fix the problem.Like my last post I went through the same thing mine even started knocking also it was the o2 sensor & didn't throw a o2 sensor code , remember if the lt1 is like the lt4 you have 2 sensors in front of the cat & 2 behind it.If you just want to throw money away I'll send you my pay-pal account ### GOOD LUCK
Old Oct 7, 2005 | 10:49 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Open your hood at night or in a darkened garage and see if you see electrical arcing off the plug wires. If not, you've probably got the Optispark Blues. It's an inevitable LT-1/LT-4 issue.
Old Oct 7, 2005 | 07:50 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Default check opti vent lines
Might it be damaged opti-spark vent lines causing intermittent moisture in the opti?
See the following link about a campaign for the 95's:
CAC 95 recall - opti vent line]CAC 95 recall
Old Oct 12, 2005 | 01:05 AM
loflite's Avatar
loflite
Finally got the car into the garage for diagnosis. Bad news. Broken valve springs on #2 and #4. One exhaust and one intake.
Old Oct 12, 2005 | 08:31 AM
aboatguy's Avatar
aboatguy
I never would have guessed that an intermittent miss was caused by two cylinders with broken springs.
Did you hurt anything else with the broken springs?
Are you going to replace them with behives or something a little more stout than the behives?
Mike
To LT-1 ignition experts
Old Oct 12, 2005 | 09:52 AM
bogus's Avatar
bogus
someone has been hitting the rev limiter. Damn.
I am glad you got it resolved!!!! Sorry it's such a pain, tho...
Old Oct 12, 2005 | 10:30 AM
loflite's Avatar
loflite
The valve springs are Manly springs put in by Doug Rippie. This is the second failure with these springs. Last time DRM covered the failure and installed new springs. I've got a call into Rippie now. Both times the failures happened cruising down the highway at about 1700 RPM. the car is not really driven very hard. Maybe that's the problem! I need to drive it harder.
Old Oct 12, 2005 | 06:39 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
He , DRM, must be using Comp Cams 941's. This is how mine happened, all 4, broke under light throttle or idle. Too fricking tight of springs. Beehives for 600lift and below. IMHO.
