Quick question. Car is a 94 with stock internals. Minor external mods such as SLP intake, Spiro pro wires, camber brace, etc.
Just put on Exotic Muscle long tube headers, Random Tech cats, and the Corsa cat-back. Now it has a very noticeable miss at idle (like it has a really big cam) and when you give it a little gas (in neutral) when you let off the gas it back fires. Loud, not just a little cough. It idled very smoothly before the exhaust was put on. We did have to remove the plugs and wires but have checked those twice to make sure they are secure.
Could it be that the ECM has to learn the new airflow so it needs to adjust the air fuel mixture? If so, how long does it take for the new settings to take affect? The battery was disconnected for two days while we did the install so it should have reset I would have thought.
THe 94 ECM doesn't realy learn so I doubt that has any thing to do with it. It could be the car has leaned out because of the exhaust and may need a tweek to the tune, ask Alvin about this one. What it sounds like to me is what happened to me a week ago and it was a burnt plug wire. I had almost the exact same indications the car seemed to have a slight miss, go figure, and it would back fire under light throttle. It only takes a second to check the wires so I would start with the simple things.
Check for spark to each cylinder, check fuel system out. I'm assuming there are no codes and the opti never got wet. It could be the O2s giving you trouble.
Merle at EM said it might just be a loose wire too. Wires are new, about 100 miles, and with the headers on it only ran for about three minutes. The miss wasn't there before the headers and it was there immediately when we fired it up so I don't think it's a burnt wire. It may be a broken insulator on a plug too.
Nothing goes easy does it?
I was going to ask if you removed or your plugs for the install a friend just did headers on his new c6 and cracked one it caused him a bunch of BS
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
This is what I'm thinking too. I don't think you can put headers in place on a C4 w/ the plugs in, I never could. It's either a damaged plug or a connection/wire problem, I'd bet on it. What kind of wires did you install? Routed properly, I don't think the wires should otherwise be a problem (in the boot area) with the EMs.
We removed the plugs before we started. It was fairly obvious that it wasn't going to happen with them in. The wires are new Spiro Pros from Taylor.
Going to try again tonight and see what happens.
If you can find one of those little inductive testers that you just lay on a wire when it's running and observe for steady (or any) spark, it'll save you time and trouble. You can pin down the cylinder(s) quickly and easily. I've got one that looks almost like an ink pen that I got as a promotional gift from Champion nearly 30 years ago. It's a neat little tool and has served me well. It still works.
I agree with the majority. It is probably a loose wire/cracked plug. My 95 has been running fine w/o a tune with my EM LTs and high flow bullet cat install.
Mine was doing the exact same thing (EM LT's/Random Techs & Corsa along with a few other engine mods). Replacing the 02's seemed to clear that issue up completely
Pulled the plug wires and plugs tonight. Found one that was dirty and wet. Wire must not have been seated all the way. Cleaned it up and put it back in. Idle is back to nice and smooth. It coughed once when the throttle was blipped but then seemed fine.
Can't really take it out and try it, raining so hard you can't see across the street. No, it's not a garage queen, but no sense driving it in bad weather when I really don't have to.
Thanks to all.
By the way the EM LT headers seem to be well made and Merle is great to deal with. The Corsa sounds good too. With the Random Tech cats everything fit very nicely and bolted right up.
Thanks to all.
Can't wait for the auto cross this weekend.
I wasn't so lucky - The fit of the cats was poor & required quite a bit of welding & some bending to fit properly.
I had similiar problems after my EM headers, RT cats, Corsa install. I relplaced my O2 sensors with HEATED O2 sensors and the problems went away. They are a little tricky becuase you have to wire the sensors to a power source but they work great.
I am not sure if your 94 has heated O2 sensors or not (I know the 92's do not).
