shock absorbers machining
Old Oct 5, 2005 | 03:56 AM
pieces_r6's Avatar
pieces_r6
Default shock absorbers machining
Hi guys
I have a Doug Rippie coil over kit that I wish to install on a new set of adjustable Koni sport shocks.
I am advised to machine a groove in each shock at about 1 inch from the bottom. As anyone already done such machining? Any concern about the thickness of the body of the shocks?
I finaly came to the coil over modification because I believe the biggest difference will be on (bad) roads and not on (good) tracks where suspensions never get in crosstalk situation.
David
Old Oct 5, 2005 | 01:15 PM
Slalom4me's Avatar
Slalom4me
I know Bilstein offers this service. Maybe check with Koni,
there might be something on their website.
DRM could probably provide some information. You might
also get better response if you create a thread in Autocross
and Racing (under General Corvette). Maybe just create a
link there to this thread so no one accuses of cross-posting.
Old Oct 6, 2005 | 01:19 PM
pieces_r6's Avatar
pieces_r6
Thanks Slalom
I've been browsing the web (many forums) about the coil over subject. It looks like it is a very delicate subject about installation on ungrooved bodies (welding and some other horror stories ...).
So finaly I e-mailed Koni and we'll see what they'll say about the shock body thickness.
About DRM, Randy couldn't give me numbers about deepness of groove. But that's true that I don't even know the diameter of the shock bodies... Hopefully it will be the same 2" diameter.
David
Old Oct 7, 2005 | 09:43 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I can't imagine who would advise you to machine a groove in the shock body, but I would not do so until Koni gives you the okay.
Good luck....and keep us posted on your project.
Larry
code5coupe
Old Oct 7, 2005 | 07:03 PM
pieces_r6's Avatar
pieces_r6
Hi Larry and all.
Well I got a reply from Koni. They strongly advise not to machine a groove in the bottom of the shock. The body is too thin (45mm int. diameter versus 50mm outside diameter).
David
Old Oct 7, 2005 | 07:13 PM
Slalom4me's Avatar
Slalom4me
Maybe sell the Konis and get the Bilsteins?
You can get them grooved and valved to suit your needs.
To shock absorbers machining
