climate control
Old Oct 5, 2005 | 03:36 PM
peggysspace@yahoo.co's Avatar
Default climate control
I have an 86 that has climate control when I push the off button it doesnt go off. can some give me a suggestion. Does it need rebuilt or can I get a spefic part
Old Oct 5, 2005 | 03:55 PM
bogus's Avatar
bogus
you can try cleaning it. I would bet that some soda or something has oozed inside the control panel.
Old Oct 6, 2005 | 12:57 AM
SunCr's Avatar
SunCr
You've posted this before - you need to be more specific: what doesn't turn off? A/C compressor - is it still engaged - lift the hood to verify if it's on or off. Blower Motor? If it's still pushing air out of the vents on high blower, that's usually in the circuit; not the dash panel. Can you raise and lower the temp? Control blower speed? Do the vents switch between Defrost, Heat and A/C?
Old Oct 10, 2005 | 02:45 PM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
Default climate Control Cleaning
Do a search on climate control. If your control buttons are not working or working consistently it's most likely your circuit board needs cleaning. I followed directions of removing the control module from the dash and cleaning the board with a pencil eraser and alcohol.
Give it a try if these are the type of problems you are encountering.
SAVE THE WAVE!
To climate control
