91 vette going crazy
Old Oct 6, 2005 | 02:05 AM
zachalak's Avatar
zachalak
4th Gear
Default 91 vette going crazy
the would run perfect till one night i started it and the starter seemed to be turning slow but the car fired up and i started driving. i looked at the battery gauge thing and saw the the needle was down near the 8 when usually its in the middle. the dash was also flashing "sys" in the screen. the next morning it starts slowly and the needle is still at the 8. when at a stop light the needle just goes down past the 8 and the whole dash goes blank and the car dies on me. i jumped and it would do the same thing a couple minutes later. what could this possibly be? thanks
Old Oct 6, 2005 | 03:14 AM
cv67's Avatar
cv67
St. Jude Donor '05
Your alternator sounds like its fried. May as well replace the battery while your'e there to keep from overheating the new alt. Had the exact same symptoms (even after the alt. tested "good").
Old Oct 6, 2005 | 03:18 AM
hippy's Avatar
hippy
Probably an alt. B4 I would throw the battery away give it a good charge as you don't want to charge a dead or low voltage battery with the alt. only.
Old Oct 6, 2005 | 03:23 AM
Corvette86's Avatar
Corvette86
St. Jude Donor '06
If your battery is shot, I recommend an Optima Yellow or Red Top.
http://www.dcbattery.com/optima_red.html
Old Oct 6, 2005 | 08:22 AM
joe3906's Avatar
joe3906
Old Oct 6, 2005 | 11:44 AM
neat's Avatar
neat
Another vote for battery and alternator.
Old Oct 6, 2005 | 12:18 PM
jfb's Avatar
jfb
Batteries are discharged at 12.0 volts! Your alternator is not charging the battery and you should have seen the red battery symbol light turned on, on the dash which tells you the alternator is not charging the battery. Charge your battery up with a battery charger and take your alternator to an auto parts store for testing and replace it if it tests defective.
To 91 vette going crazy
