ABS error code 61: Dlr says pump is dead
Old Oct 6, 2005 | 11:00 PM
Tri-black91's Avatar
Tri-black91
2nd Gear
Default ABS error code 61: Dlr says pump is dead
My Chev mechanic of whom I trust says that the abs pump is out. He did the testing from the service manual, plus the electrical troubleshooting with all the relays, connectors, grounds. Has any body ever had their abs pump motor go out? This pump is located behind the driver seat in the storage well.
This part is not available through chevy any more. I found plenty to choose from at car-parts.com. They are going from $100 to $300 The origional list was $1200+ (for new) Any suggestions.....Im into this project $400 so far and no end in sight. The error code is 61.
Old Oct 8, 2005 | 11:01 AM
dlmeyers's Avatar
dlmeyers
Consider Ebay. Make sure you know the part number on the pump. I've gotten the controller AND the pump for around $160. There are lots of pumps around, they seldom go bad.
The dealer may install a pump provided by you. If not, you should be able to find a mechanic that can switch them out, bleed the brakes, clear the code, etc.
Personally, I like the ABS brakes but they are essentially an option on new cars these days.
Good luck with this repair.
dlmeyers 90 coupe zf6 3 speed shocks
Old Oct 9, 2005 | 10:46 PM
Tri-black91
2nd Gear
Thanks for the advice! Ill try my search on E-bay.
Old Oct 10, 2005 | 12:34 PM
azzkikr's Avatar
azzkikr
Just my .02 cents...
Years ago, a so called mechanic worked on my vette... I got it back and the ABS was shorted out. I then went to a very respected mechanic that worked at a dealership to find out what had happened and what my options were. The parts were going to be very expensive... he gave me a bit of inexpensive advise - he simply unplugged the unit, I tipped him $20.00 and I've been trouble free ever since. If you really want to get everything working, I agree with the other guys... check out the auctions, I've found a lot of great deals. Good luck with your project.
To ABS error code 61: Dlr says pump is dead
