Another Brake Hose Question
Old Oct 7, 2005 | 11:52 AM
myblue91's Avatar
myblue91
Default Another Brake Hose Question
Will be replacing all my brake hoses this weekend and my question is,for those in the know, Looking at the Helm's manual it says to replace the 2 aluminum gaskets(washers) on each side of the hose which connects to the caliper. Now, can I use copper washers instead? Any other advice welcome since I've never done this before.Thanks And one last question, I've got 2 new drilled and slotted rotors from 96zride,freebees!!! Thanks again Mike, that I'll put on,and need to know what size is the mounting plate bolts? That's all for now
Old Oct 7, 2005 | 12:02 PM
bogus's Avatar
bogus
I am not sure how copper would react to brake fluid. I would get aluminum.
Old Oct 7, 2005 | 12:05 PM
chucks88's Avatar
chucks88
I always thought those were brass.
Old Oct 7, 2005 | 12:07 PM
adi4's Avatar
adi4
There is no problem with either copper or ally washers with brake fluid
Old Oct 7, 2005 | 12:14 PM
myblue91's Avatar
myblue91
Bogus- that was my concern, got a set of washers from Corvette Central,and they're copper, not brass like the hose ends. May be putting this off till I get the right washers. Do have both a Hayne's and Chilton manual(go ahead and rag on me!!!,but they do have some good pictures) and one of them talks about copper washers.
Old Oct 7, 2005 | 12:30 PM
deerra's Avatar
deerra
Maybe I can help. I used to restore and work on Triumph motorcycles. The bikes came from the factory with copper washers and head gaskets. In order to re-use them, we heated them with a torch to cherry red, dunked them in water, scrapped off any black residue and installed them. The heat makes them "mallable" so they'll seal. Hope this helps.
Old Oct 7, 2005 | 12:36 PM
myblue91's Avatar
myblue91
[QUOTE=adi4]There is no problem with either copper or ally washers with brake fluid
These are the reasons this forums so Great!! Thanks adi4. Now how bout' those bolts, I'm guessing 19mm?
Old Oct 7, 2005 | 12:39 PM
myblue91's Avatar
myblue91
This is getting more interesting?? which is softer,copper or brass??
To Another Brake Hose Question
