Converting to heated sensors?
Old Oct 8, 2005 | 04:07 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Converting to heated sensors?
How doyou convert single wire O2's to multy wired Heated O2's?
Old Oct 8, 2005 | 09:13 AM
Pete K's Avatar
Pete K
The new sensor will have 2 white wires and 1 black. The black connects to the existing o2 wire. It is the signal to the ecm. One of the white wires goes to 12 volt ignition power. The other white goes to ground.
Old Oct 8, 2005 | 12:41 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Is this what you're looking for Steve? I've been meaning to put this in the for sell section since the DFI system going on has it's own wide band sensor.
Old Oct 8, 2005 | 02:18 PM
steve40th's Avatar
steve40th
Yes, PM me with the price etc if you dont mind.
Old Oct 8, 2005 | 11:32 PM
mike t's Avatar
mike t
I would like to change my O2 sensors. Not sure what is advantage of heated. Do not know if they are heated on my 95. Anyway, would like to know price if possible. Thank you
Old Oct 9, 2005 | 11:08 AM
Ramrod92's Avatar
Ramrod92
Mike, I don't think any of the LT1s came with heated sensors. Take a look at this heated O2 sensor link
Old Oct 9, 2005 | 12:13 PM
Slalom4me's Avatar
Slalom4me
Thanks for the link.
Any idea why the MAF is chosen over, say, the switched 12VDC
source for the distributer? This is physically closer to the O2 location.
Is there a nearby MAF relay on the firewall to tap into?
Regarding the suggestion to use a 3-wire Weatherpack. Instead of
changing away from the OEM 1-wire connector on my '89, I am going
to transfer the sensor-side connector from an old O2 to the black
wire on a heated O2 so that I can retain the OEM connector on the
harness. I'll use a 2-wire connector for the 12VDC and ground leads.
Old Oct 9, 2005 | 12:21 PM
Ramrod92's Avatar
Ramrod92
I don't know how well you can tell from the picture, but I used the wire w/connector from an old sensor so you don't have to cut your stock harness and you will be able to change the new 3 wire sensor out without any problem.
Old Oct 9, 2005 | 01:29 PM
Slalom4me's Avatar
Slalom4me
If the O2 sensor gets moved downstream, as happens with long
tube headers, then there may be circumstances when an unheated
one does not warm up enough to create a signal.
With no signal from the O2, the ECM defaults to 'open-loop' mode
and modulates A/F based on predetermined values instead of
what it reads from the exhaust.
Several on-line sites have application guides to walk you through
a selection for your car and give you an idea of pricing.
Old Oct 9, 2005 | 01:36 PM
Slalom4me's Avatar
Slalom4me
Yes, that's what I had in mind. Sorry, I was referring to the suggestion
on the link and hadn't looked closely enough at your harness.
I elected to get the 'Universal' version of a 3-wire heated sensor.
These are the same sensor but they are sold with an unfinished end
so I'm not trying hook to an existing Weatherpack.
Old Oct 9, 2005 | 06:29 PM
comp's Avatar
comp
Old Oct 10, 2005 | 09:21 PM
mike t's Avatar
mike t
Thanks, ok then, seems there is not a need for heated O2 sensors.
To Converting to heated sensors?
