'93 stalled out in traffic
Old Oct 8, 2005 | 03:32 PM
crkemppainen's Avatar
crkemppainen
Default '93 stalled out in traffic
While driving in traffic, the engine stalled on me. i was able to restart it and get to the nearest parking lot, but it kept stalling on me, shutting off several times in less than a block. i was able to start it in neutral, but after slipping it into drive, it would only pull for about 5 seconds, then die again.
that same stuff happened before, when my ICM went out, but it threw a code when that happened...not this time...
the car has eaten 2 ICMs in the last 5000 miles or so, and now i suspect this one will need to be replaced too...
Why does my car keep eating ICMs?
Why does it start and run fine now, after sitting for 3 days?
Why was there no codes when it cut out on me?
does anyone want to buy this thing from me- I'll make it cheap
Ryan Kemppainen
Old Oct 8, 2005 | 03:34 PM
bogus's Avatar
bogus
ICM? Ignition Control Module? The little thing behind the coil?
I would check the harness... There was a long thread by JetJockey93 that outlines this problem.
As for stalling, I would suspect the IAC - Idle Air Controller.
