My clutch has been slipping ,after removing it I noticed very uneven ware on the flywheel (aluminium with steel insert).
My question is can I have all componants rebuilt including the flywheel?
and how much would I save?
The flywheel should be rebuildable, drill out the rivets and install new steel insert. I'm not sure if McLeod sells a kit or does it as a service though.
