ZF6 conversion... what speedo gear?
Old Oct 11, 2005 | 10:14 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default ZF6 conversion... what speedo gear?
What rear end ratios came in 1989? I've got a 1989 ZF I'm dropping in my 85 vette with 3.07 rear end. Also wondering if that 3.07 rear is gonna need to be shorter to make my .5:1 overdrive useable.
Do I need a different speedo gear, and if so, will my 4+3 speedo gear fit in the tailpiece of the ZF?
Old Oct 11, 2005 | 10:52 PM
bogus's Avatar
bogus
I honestly don't know. However, I think that www.zfdoc.com might have the answer. If not, call him, and I am sure he can give you the answer.
There is also a chance that the 3.07 gear was used with that ZF6. I think they are colour coded... I just don't know the code.
I am sure this has been of little help, really.
Old Oct 11, 2005 | 11:13 PM
CentralCoaster
Ok then. Why is the sky blue? What does ZF stand for? What does 4+3 equal?
Damn. CAC shows 5 or 6 different ratios. I'm sure at least 3 of the short ones were available on the stick. I guess it's a poop shoot here. I'll check for color codes.
Old Oct 11, 2005 | 11:19 PM
CentralCoaster
p/n 10456089
Also has "DR" molded in the plastic. Is black, no sort of painted on color coding.
Old Oct 11, 2005 | 11:26 PM
CentralCoaster
Eureka!
http://www.corvetteforum.net/c4/vett...Gearshtm.shtml
This came outta a 91 with a 3.45 OR 3.54 rear end. Hmm. One speedo gear for TWO ratios? Looks like the drive gear has one tooth difference.
Numbers on the tag seemed to indicate it was from an 89.
My 85's speedo has the same number of driven teeth as what's in this ZF. Interesting.
So these drive gear, driven gear are all easily swappable? Wonder if my 4+3 parts willl fit in there.
Old Oct 11, 2005 | 11:43 PM
rodj's Avatar
rodj
Driven gear is on the output shaft under the ext housing.
If you are lucky it will take the same style gear as an auto / 4+3 so you will be able to use your original gears unless you have changed tyre sizes.
Speedo calc shows 19 tooth driving 45.
Mr CFI-EFI will know exactly.
Old Oct 14, 2005 | 01:56 PM
vettef6's Avatar
vettef6
I have a complete list of drive gear combinations, part#'s, colors etc.!!
If someone can tell me how to post, then I will do so.
Old Oct 14, 2005 | 02:00 PM
89sleeper's Avatar
89sleeper
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
Both my 89s coupe and roadster have 3:54 gears in rear axle both are 6 speeds
Old Oct 14, 2005 | 03:02 PM
LD85's Avatar
LD85
You can not get a red 3.07 tranny gear, they dont make it for the ZF, but you can call ZFDOC, the last time I talked with him, he was going to make some .
Otherwise, I used the Dakota Digital speedo calibrator on my 85 with 3.07's, but now I have 3.42's.
Old Oct 15, 2005 | 12:28 AM
CentralCoaster
I like that idea better. Surely I'll want to put a lower gear in after this. I mean, what am I gonna do? Drive the damn thing?
WTF is a 3.42? never heard of that ratio...
Old Oct 15, 2005 | 04:26 AM
vettef6's Avatar
vettef6
LD85 probably means 3.45!!
Old Oct 15, 2005 | 08:49 AM
LD85's Avatar
LD85
Sorry for the typo,
yes I have 3.45's, but the 3.45 is discontinued from production from what I was told by several Ring & Pinion manufacturers
and had I not bought a used set of 3.45's I would have HAD to buy 3.45's, so if you look for gears 3.45'3 may be hard to come buy
Old Oct 26, 2005 | 01:13 AM
vince86's Avatar
vince86
I just reused my 4+3 speedo and gear....b/c it fit...it works fine. But, mine is a black tag...early model tranny. I would say, if the gear fits, wear it.....uuuuh? wait a minute... I mean put it in and try bench testing it. Mine works fine, like I say.....I have the 3.07. And on your ZF tag.....if it has a blue tag and has a crash through style for the reverse lockout...it is a later model 92??-96 if it's a collar lockout and black tag it is an early model such as an 89-91. What I did was put my gear in there and looked to see if the gear was off center or not...it was dead center and the teeth went together fine.
Old Oct 26, 2005 | 01:41 AM
CentralCoaster
Good to hear. I do have a black tag. Not sure about the shifter, I identified it by the tag that is black.
The shift **** is the same part number too.
Old Oct 26, 2005 | 05:06 AM
pablocruise's Avatar
pablocruise
That's pretty cool. Mine has 3:33's.
I was mistakenly under the impression all 89's w/ 6 speeds had 3:33's.
To ZF6 conversion... what speedo gear?
