Refinishing Hard Top questions
In order to paint the top I need to carefully remove the metal trim piece that wraps around the sides and front.
The questions I have are as follows:
1) How do I remove the trim piece without bending it. Should I use a heat gun to soften the glue.
2) I was told by a corvette top specialist that I should use stripper to remove the current paint. But, I have also heard that the stripper softens fiberglass. I know that sanding can leave flat spots. If I use stripper is there a special brand or do I just use the hardware store brand?
3) How do I remove the headliner? With a heat gun?
4) Lastly, what type of glue do I use to reinstall the headliner and the metal trim strip after re-painting the top?
Any inputs or advice from those that have experience with painting and/or refurbishing these tops would be great!!!!
Thanks, Blacky
Thanks, Blacky
2. I just used aircraft paint stripper, quick on, quick off. Light sanding in long strokes covering the full top.
3. Headliner: just peeled it off then cleaned with adhesive remover.
4. Headliner: 3m heavy duty adhesive spray, and for trim: clear weatherstrip adhesive.
Hope it helps... the more time you spend the better it will be
body filler card,
Don't let the stripper harden you will never get it off.
Don't do it in the sun and wear gloves.
I use Laquer thinner along with adhesive remover to take off the glue but don't get on the foam.
Thats all folks!
