oil pressure sending unit
Old Oct 12, 2005 | 08:12 AM
dogbon's Avatar
dogbon
Default oil pressure sending unit
There are two seperate sending units at the back of the intake manifold on my '86 coupe. One is a cannister with a single prong electrical connection and the second is a smaller sending unit with two prongs. Which is the sending unit for the oil pressure guage? I'm down right now doing an engine swap, so I can't just fire it up and check.
Old Oct 12, 2005 | 08:15 AM
JackDidley's Avatar
JackDidley
The single connection is the gage. the double is a switch. I would put in a new switch with the motor. They tend to leak.
Old Oct 12, 2005 | 08:19 AM
dogbon's Avatar
dogbon
What does the switch activate?
Old Oct 12, 2005 | 08:28 AM
JackDidley's Avatar
JackDidley
Powers the fuel pump.
Old Oct 12, 2005 | 08:33 AM
as long as it is red's Avatar
Default The switch
tells the computer to activate the ignition when enough oil pressure is detected. The are prone to leaking through the ecectrical part of the unit and they will pour oil through the wire connections. To install the unit properly, you will have to get a special socket. THis is a must have part and it needs to function properly. Let us know how the motor swap goes.
Old Oct 12, 2005 | 09:25 AM
dogbon's Avatar
dogbon
Which is it?? Powers fuel pump or ignition?
Old Oct 12, 2005 | 09:46 AM
Default Correction
It is the fuel pump. Sorry for the misinformation.
Old Oct 12, 2005 | 09:53 AM
dogbon's Avatar
dogbon
Thanks guys, I'm back to the creeper again tonight.
Old Oct 12, 2005 | 10:00 AM
scorp508's Avatar
scorp508
More infomation on the switch.
The switch monitors the oil pressure in the engine. As long as there is sufficient oil pressure it supplies a power feed to your fuel pump that is independent of the fuel pump relay. If your fuel pump relay were to die while driving down the road, this switch would keep you running.
If you ever turn your key to 'on' and do not hear the fuel pump prime, but you CAN start the car with some extended cranking (buildng oil pressure) then it is a good idea to test your FP relay.
Old Oct 12, 2005 | 10:36 AM
vader86's Avatar
vader86
One other thing, its not a safety switch, if your pressure drops to zero, it will not send a kill signal to the ignition.
Old Oct 12, 2005 | 10:42 AM
scorp508's Avatar
scorp508
Well yeah sorta kinda pretty much.... it will though kill power to the fuel pump, but that doesn't matter since the fuel pump relay will still be powering it.
Old Oct 12, 2005 | 01:54 PM
vader86's Avatar
vader86
making it pretty much useless, it would be nice if it killed power to both
Old Oct 12, 2005 | 07:43 PM
CFI-EFI's Avatar
CFI-EFI
It might seem that way if you've never had a fuel pump relay fail. Go ahead and rewire yours, in a series.
RACE ON!!!
Old Oct 12, 2005 | 10:36 PM
scorp508's Avatar
scorp508
Well... I for one wouldn't want my engine qutting and my rear end locking up at 80 MPH.
Old Oct 12, 2005 | 11:04 PM
vader86's Avatar
vader86
No more than you would want the engine to keep running at said 80mph when oil pressure drops to zero.
To oil pressure sending unit
