Rear End Identification
Old Oct 12, 2005 | 12:58 PM
jughead1's Avatar
jughead1
From: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
Default Rear End Identification
I am about to arrange to look at a complete rear end assembly. Since it is about 60 miles away I need some information to know exactly what I'm looking at and I can think of no better source than you guys. The present owner can't tell me anything except it is from a C4 and he thinks it is from an auto transmission. If it is a 3.07 and in good shape I would definitely be interested. My questions to you guys are;
- can you determine the gear ratio by any external stamping or number?
- how do I determine if it is a Dana 36 or 44? I know they look similar but how could I identify the difference by eye?
- are all C4 rear end units interchangeable?
Any help would be appreciated.
Old Oct 12, 2005 | 01:17 PM
bogus's Avatar
bogus
Look at the case. Somewhere is a raised imprint of what it came with.
The D36 can have 2.59 or 3.07. The D44 can have 3.07 or more.
There are other external differences, but I don't remember all of them.
As far as I know, all rears are interchangable within the car... but I am not 100% sure. Something is bugging me in the back of my mind...
Old Oct 12, 2005 | 02:47 PM
Bob CTS's Avatar
Bob CTS
I think that a D44 has three bolts at the top of the diff, and the D36 has two. This is going off my memory though.
Bob
Old Oct 12, 2005 | 03:27 PM
mash557's Avatar
mash557
As far as ratio, the tooth count of the gears should be scribed into the bottom of the case, my D36 was. Quick test of ratio, especially if it is out of the car is to count the number of turns of the pinion flange it takes to turn the axle one time. about 2 and a half would be 2.59, just over 3 and 3.07, ecetera. I believe the C-beams for the D36 and D44 are different, but that also may be due to D44 only coming with manual tranny from factory. Helms lists following that is electro etched into the bottom of the differential carrier. D36 - GM part# 14093142 (2.59), 14087678 (3.07 w/G92), 14087676 (3.07 w/Z51) D44 is 14087652 (3.07) These are from 1986 manual. Also just noticed, but ratio should be there as well as tooth count. Good Luck
Old Oct 12, 2005 | 04:00 PM
GUSTO14's Avatar
GUSTO14
Actually there is a plethora of information stamped into the Dana rear ends. Everything from ratio to manufacturing dates, etc. But the most important thing is that the top rear of the D-44 has two bolts in it and the D-36 has but one in the center.
Good luck, GUSTO
aboatguy's Avatar
aboatguy
Bob
I think you have it ackbasswards!
Old Oct 12, 2005 | 04:58 PM
GUSTO14's Avatar
GUSTO14
If you go here,
http://www.ikerds.com/catalog/1984-1996.html
...they have very good images of both rear covers, as well as the differentials.
GUSTO
Old Oct 12, 2005 | 05:15 PM
jughead1's Avatar
jughead1
St. Jude Donor '11
Thanks Guys.
I was able to chase down a 93 factory service manual and found what I needed. According to the diagram in the GM book... the D44 has two cover bolts on top and the D36 has three. All of the information...Dana #, GM # and ratio SHOULD be on the right side of the unit. I just can't tell if it is stamped on on a plate.
For anyone else in the future the 93 P/N's are;
Dana36
GM1-2.59, P/N 10046613
GU2-2.73, P/N 10046614
G44-3.07, P/N 10046615
Dana44
GT7-3.33, P/N 10126418
GM3-3.45, P/N 10126476
As usual you guys got me headed in the right direction!
Thanks again!
Old Oct 13, 2005 | 07:01 AM
Bob CTS's Avatar
Bob CTS
As I said going of memory not correct 100% of the time
Old Oct 13, 2005 | 07:55 AM
comp's Avatar
comp
Originally Posted by GUSTO14
If you go here,
GUSTO
Old Oct 13, 2005 | 09:45 AM
aboatguy's Avatar
aboatguy
Originally Posted by jughead1
Thanks Guys.
Dana36
Dana44
Thanks again!
On my 36 hanging in the shed and the 44 in the car the gear ratio and other info is engraved on the diff.
Mike
Old Oct 13, 2005 | 09:47 AM
aboatguy's Avatar
aboatguy
Dude I was not flaming you. I thought you were wrong so I went out to the shed and checked before posting.
I have found some errors in the Helms so I check first hand if I can.
Old Oct 13, 2005 | 10:00 AM
Bob CTS's Avatar
Bob CTS
No problem I was at work and could not look at the car, and I archived the gasket that I drew for the differential so that was at home as well.
Bob
To Rear End Identification
