Battery or Electrical Problem?
Old Oct 12, 2005 | 01:43 PM
00Nassau's Avatar
00Nassau
St. Jude Donor '11
Default Battery or Electrical Problem?
I have a 95 Pace Car that is driven very little. I use a battery disconnect and a battery tender when it is sitting in the garage. I tried to start it last night and it will not crank at all. The battery has 12.4 volts when sitting with the key off. The voltage goes down to 9.9 volts when the key is turned on and the dash lights dim and the only sound is a clicking somewhere at the front of the engine/radiator/fans area.
The battery is about 4 years old and appears ok when I hook it up to a regular battery charger and shows good on the battery tender.
Do I have a bad battery or an electrical problem?
Thanks for the help!!!
Old Oct 12, 2005 | 01:48 PM
comp's Avatar
comp
sounds like batt. can you check the cell level's ???? also do you have a charger with a high rate of charge
Old Oct 12, 2005 | 01:53 PM
89sleeper's Avatar
89sleeper
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
See if the car starts by jump starting it if it does have your battery load tested it my have a weak cell!
Also check voltage output when motor is running it should be around 14 volts!
Old Oct 12, 2005 | 02:30 PM
rstackjd's Avatar
rstackjd
Out of curiosty - if the voltage meter shows about 13.5 when driving does that mean anything? Mine will be high after start-up (13.8/.9) but drop to 13.4-.6 after a little while. ('88 btw)
Old Oct 12, 2005 | 02:50 PM
generalkorrd's Avatar
generalkorrd
8th Gear
Sounds like the batt is bad. Also check the connections between the batt and the car.
Old Oct 12, 2005 | 03:12 PM
swifty's Avatar
swifty
9.5 volts while cranking is not good. A dynamic tester loads the battery three consecutive times in about 30 seconds - if the voltage drops below 10.5 while loaded it is time for a new battery. Good luck.
00Nassau's Avatar
00Nassau
St. Jude Donor '11
Thanks for the suggestions. I am going to go ahead and pull the battery out tonight and get it load tested tomorrow. It really doesn't take that long to take out the battery, but it is just a PITA to have to pull the side panel off the car.
Old Oct 13, 2005 | 12:59 AM
jfb's Avatar
jfb
I would suspect the battery disconnect. The starter draws 100+ amps to crank and it cannot tolerate any resistance in the circuit from the battery to the starter. When you disconnect your battery cables for the load test, observe if the cable lugs and the battery posts are clean and bright. If not, clean them. Also, the battery should measure higher than 12.4 volts if it is fully charged and your battery tender should keep it fully charged. 12.0 volts and below, discharged. 12.9 volts and above, fully charged. 12.4 volts is only 40% charged. Have your battery load tested, at 4 years it is also suspect. My 6 yr guarantee battery quit last month at 3 years old.
Old Oct 13, 2005 | 08:48 AM
Paul Workman's Avatar
Paul Workman
Default 13.5 volts when running is a GOOD thing...
The 13.5 to 14+ is when the alternator is charging the battery. That is how you know the alternator/regulator is working. A reading of ~12.5 or less when the engine is running means trouble - usually the regulator/alternator or a connection.
As for your situation, if the voltage drops to 9.9 when you turn the key on, but the engine can be jump started OK, then I agree w/ others that the battery or a connection is suspect. Check/clean the batt connections, and if that doesn't cure it, have it load tested before proceeding. I'm guessing it is a battery or a connection problem.
Good luck!
P.
Old Oct 13, 2005 | 09:21 AM
00Nassau's Avatar
00Nassau
St. Jude Donor '11
I pulled the battery out last night, and when I tested it on the work bench it only had 12.1 volts. I am going to load test it on the way home this evening, but I'm betting it is the battery.
Thanks for all the responses!!!
Old Oct 14, 2005 | 09:33 AM
00Nassau's Avatar
00Nassau
St. Jude Donor '11
I bought a new battery. I tested the voltage before I put it in and it only had 12.2 volts. I was expecting something more in the 12.9 volts range. The car started right up.
Thanks for all the help!
To Battery or Electrical Problem?
