Tranny experts step inside......(PeteK especially)
1.What are the Mph points that the 2 gear downshift should occur?
currently it will down shift 3-1 below 30mph and 4-2 @62mph or lower I am trying to remember but I thought the 4-2 downshift occured at 65mph before mabey even 66mph.It will wind out in 2nd to 76mph and shift at 5krpm.Once it hits 3rd above 30mph it will only drop into 2nd.
2.What rpm should it upshift at. I know 1st is a little low at ~4600rpm,2nd@~5krpm(used to be closer to 5500rpm).I haven't wound out third yet.What needs to be done to get the right shift points.
3.The Trans go kit hits 1st pretty hard at light,medium and WOT.Should it be somewhat smooth at light throttle?The only way I can get it to shift without snapping my neck is to let off just before the 1-2 shift.Is this how it is supposed to work?Will it smooth out after break in?
I have a drip at the rear seal so it is going back on Monday and I want to be able to get fixed what I can at that time.Am I expecting too much?
Over all it makes quite a difference though the car is much smoother and gotta love the bark going into 2nd at WOT but because it bangs so hard at light throttle I am concerned I won't be able to drive it in winter weather.ASR kicks in every 1-2 shift on even damp roads.
On the TV cable if it is shortened to smooth out the 1-2 shift I loose the WOT shifts at 5k to 4.5k,If I lengthen it to get higher rpm 1st shift the other gear shift points raise up too much and the 1-2 shift is really hard.
1) I am very cheap
2) I got tired of paying good money to pro's for sh*tty work.
3) I enjoy the heck out of working with my hands. I am very detail oriented.
Although I could probably make a living doing transmissions, I would never pretend to know more than I do in this area. I will keep my snoot in the gm books and see what I find. Your guy sounds like a good one. Don't give up on him yet.
1) I am very cheap
1. My 99 coupe has only 20,XXX miles. A4 Tranny was running 200+ degrees in summer. I put on a B&M 24,000 BTU Tranny cooler. After that it was running 169-172 degrees.
2. I was told that when you put the Transgo shift kit, it clears some passages in the Tranny, and makes the shifts Quick and firm. THIS reduces the heat in tranny, therefore, making it run cooler.
3. I just put in the shift kit yesterday. I was hoping for neck-snapping shift (my mechanic told me I'd get after installing this kit), which didn't happen.
.....After Transgo kit insatallation, now my Tranny TEMPS are running 210-215 degrees. The outside temps are much lower now than in Summer, so why is my Tranny TEMPS gone from 170 to 215 with Transgo Kit ?
Wasn't it supposed to go lower according to what I was told. Even if it doesn't go down, why is it going up so dramatically?
I am very upset and disappointed with this... Plz tell me what's wrong here ? I will highly appreciate any inpute and advise. Thanks in advance.
I had another tranny with the "trick shift" done to it which is the ugly way of drilling and pluging and I thought it hit so hard it would take out the universals.A true BANG every shift.The trans go is not quite that hard and there is no "bang" with it but it will bark the tires under medium throttle 1-2 shifts easily and all other gears are definately firmer to I even got a little bark from 2-3 sometimes.
A shift kit will not work right in a worn out tranny either how many miles on the tranny?
Highest stagebefore full manual shift.
Was advised not to step up to larger boost valve (.500?) as too hard.
With stock boost valve , shifts VERY firm at part throttle , but sure as hell kicks **** at WOT.Super smooth / fast tyre chirping shifts .
Adjusting the shift via the TV cable is not the way tofit your problem.
