85 -Weird BLM readings
Old Oct 14, 2005 | 08:31 PM
62k's Avatar
62k
Default 85 -Weird BLM readings
Have been fighting lean mixture problem and high oxides of nitrogin. Most of the problem was in the air pump system including the diverter and switching valve. I did get the integrator numbers within proper range. As I was viewing the BLM numbers with my Auto Xray as the engine was running the digets would start with 1 and increase to ,I think, 250 and then begin all over again. Would that be the scanner, or the ECM, or what. How can the integrator numbers be normal and the BLM so screwed up????? I also noticed that as soon as the engine goes into closed loop I get a lean flag mixture reading. No trouble codes, seems to run good. I need some help from a higher power than myself....
Thanks in advance.....
Old Oct 14, 2005 | 08:53 PM
Bluevette85's Avatar
Bluevette85
If you do a search, other people have reported problems with using an Autoxray with the 85 ecm.
Old Oct 15, 2005 | 07:57 PM
62k's Avatar
62k
Thanks, I'll give it a shot..Too many malfunctions and not enough answers. What type of scanner do you use for your 85????
Old Oct 15, 2005 | 09:01 PM
Morley's Avatar
Morley
WinALDL & a laptop.
Old Oct 15, 2005 | 09:35 PM
Bluevette85
I used Winaldl but I have converted to the 165 ecm so I use Tunerpro and Datamaster.
Old Oct 16, 2005 | 06:41 PM
62k's Avatar
62k
How did you get the different ecm to function with the 85 schmatics and wire loom? I'm not in that arena yet.
Thanks for the suggestions. I haven't had anyone indicate similiar problems with their Auto Xray. There's always tomorrow....
Old Oct 16, 2005 | 09:30 PM
Bluevette85
Here's how to adapt to the 165 ecm
870 to 165 Instructions
As I suggested earlier, use the search for 'autoxray 85' and you will find many people with the same problem.
Old Oct 18, 2005 | 01:53 PM
62k's Avatar
62k
I placed a search concerning the AutoXray on this forum with no replies to date. Where else would one place a search?
Thanks again
62k
Old Oct 18, 2005 | 04:35 PM
Bluevette85
Use the 'Search' button at the top of the page. Go to the advanced search and select archive then highlight C4 Corvettes.
Old Oct 19, 2005 | 08:19 PM
62k's Avatar
62k
Oh...
Bit the bullet today and revisited the emission police on the chance that the integrater numbers were correct, 125 to o/a 135, and the BLM numbers 1 to 250 was a malfunction of the scanner. To my amazement the old 383-85 passed with flying colors. The culprit all along was the air pump system. The check valves, diverter and switch valves were defunct which was causing a high reading of oxides of nitrogin, a no pass.
Thanks again for your help and suggestions.
62k
Old Oct 22, 2005 | 11:50 AM
MrNuke's Avatar
MrNuke
I get the same thing of the BLM #'s counting from 1 to 254 then restarting with WinALDL. I think it's an '870 ecm thing..
Old Nov 1, 2005 | 12:33 AM
GRX's Avatar
GRX
Oh...
62k
62k,
Did you replace all the divert valves? Why were they causing a lean condition? I think I may have a similar situation. Thx!
Old Nov 1, 2005 | 02:54 AM
Morley's Avatar
Morley
That is a "BLM count"...only ever seen it on the 870's. If you look at the scanned data you should see another BLM with numbers like your INT is showing.
To 85 -Weird BLM readings
