For those that have seen my recent threads about the motor re-do, here's an update:
Take a look at the bearings from the last motor. I'm pretty sure this caused the rod knock
Here's the old girl naked:
Here's a shot of the new heads/intake from Precision Porting:
The finished product ready to drop in on Monday:
Anyone know how I can get the pictures to show up and not just the links? I should probably shrink the filesize if I do that.
No real snags other than waiting for parts and 1,267 trips to the parts store to get gaskets. I'd guess it takes about $200 in gaskets to rebuild an LT1. Unbelievable. And that doesn't count bolts, plugs, and frickin' RTV sealant. Add another $100 for that crap. And brake clean, and mineral spirits, and on and on...
Click on the "Browse" button, select the picture you want from your computer, click "Open", then click "Upload" at the bottom of the page. A new page at the bottom comes up with your photo. From there just right click, copy, and paste the link in the "Url" box onto your posts here on the forum just like that. You'll have pictures and not links in your posts now.
Repeat for each additional photo you wish to post.
When you realize how much it costs to replace a C4
windshield (the right way), you won't be using the
cowl as a tool caddy. Oughta find another spot for
the alternator.
Glad to see that everything is coming together well.
the alternator.
I'll follow up on that. Or rest your hand on the base of the windshield for support.
the alternator.
How much? I have found out why you don't set the airbox there. Luckily the windshield has scratched and I was going to replace it anyway, just not so soon.
The common denominator to the cheap fix is that
the current seals and trim are reused. If I could
remove and clean the trim as one person did, I'd
consider reuse. But I'd always choose a new OEM
seal to reduce the possibility of leaks and rework.
the alternator.
It's actually not on the cowl, it's resting just above where the computer sits, kind of on the computer bracket and the hood latch plate. Not that this is the best place for it, either :o You know how it goes, it would have taken at LEAST 2.4 minutes to undo that one bolt holding the alternator wires on so I could set it on the bench. Plus 2.4 minutes to put it back on later.
I do put tools there all the time, however. Good tip...I'll change my ways. She cost me enough money this month!
I don't mean to be rude, but I gotta ask...why go thru the hassle of removing the hood? New carbon fiber one on the way?
FWIW, you can practically fully dress the engine prior to install...plugs, plug wires, ps pump, etc. It'll save a little time upon reassembly
Yeah, I know you don't have to remove it but it just makes things easier. It's only eight bolts and a prop rod, took ten minutes. It's nice to not have it there since the workbench is sitting right if front of the car.
It's basically dressed, I just need to put the spark plugs and wires on. The PS pump is still in the car, getting the lines on it is easier with the motor out, worth putting it back on in the car.
Alternator's easy enough in or out. Plus it's holding the windsheild down right now
Motor's in and just about everything's hooked up. I need to bolt the motor mounts and trans back in, do a final check, pray to all dieties I can think of, and fire it up.
Good lord, this takes a long time. I've been saying "tonight's the night" since Saturday. Had one scare when a flywheel bolt stripped (damn aluminum), but a helicoil sleeve fixed that up. Then we lost the bolt for that hole...spent 20 minutes looking for it as I got closer and closer to panicing.
Then, assuming it actually starts (has anyone had this happen on the first try?), there's mating the exhaust to the headers, hooking up the electric WP, adding fluids, breaking it in, etc.
Instead of cranking it up I spent 5 hours trying to get those little square-head plugs out of the heads. After breaking 2 ratchets, 5 adapters, 10 knuckles, and running out of ideas I gave up.
Time to drill the ****'s out. Guess I'm tracking the M3 on Saturday.
Surprisingly enough, I did. Of course it ran about thirty seconds and died, but hey, it started. It cranked back up and ran after that though, thank God. Good luck with it!
