Does Anybody Know???
Old Oct 15, 2005 | 07:33 PM
SPEED750's Avatar
SPEED750
Default Does Anybody Know???
if an F body LT1 oilpan will fit a 92 LT1 vette?
Old Oct 15, 2005 | 09:18 PM
SPEED750's Avatar
SPEED750
Old Oct 16, 2005 | 12:00 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
It should, but why?
I see you are in the panhandle of FL, I'm near Mobile and have a spare LT1 vette pan if you need it
Old Oct 16, 2005 | 12:36 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I looked at and measured both. Distance to the bottom from the rails is identical front and rear. The only real difference I see is that the drain plug is on the LH side directly down from the oil level sensor, whereas on the Vette pan it's at the rear. Since there is nothing underneath the pan under all but the very front of it, there are no clearance problems.
BTW, if you want Vetteman's Corvette pan instead of the F-body one, go for it. It won't hurt my feelings a bit.
To Does Anybody Know???
