cut air box lid
Old Oct 16, 2005 | 05:01 PM
the blur's Avatar
the blur
Default cut air box lid
I have a STOCK LT4, and I came across an extra air box lid. Would it pay to cut up the lid? Would the OE LT4 programming be able to deal with the extra air flow?? I wouldn't want it to run lean...
Old Oct 16, 2005 | 05:09 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Cutting the lid and installing a K&N should be worth 10chp.
The power vs A/F curve is broad enough that this mod should not run you too lean at WOT with an otherwise bone stock LT4. If you make other air flow mods you might want to add an AFPR to get full benefit from them.
Old Oct 16, 2005 | 11:06 PM
the blur's Avatar
the blur
I just plan on removing every other fin. so a 50% decrease of restriction... No K&N, just keeping the current filter. So I'm thinking the PCM should be able to handle that..
thx
Old Oct 16, 2005 | 11:09 PM
cv67's Avatar
cv67
St. Jude Donor '05
thx
Yes, with no problem.
Old Oct 17, 2005 | 07:50 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I wouldn't bother, on an otherwise stock LT4 I doubt you will see any gain. You will however, be cleaning your filter more often.
Old Oct 17, 2005 | 11:14 AM
MYCoupe's Avatar
MYCoupe
On a stock car it's not going to make a difference. Once you start doing heads and cam it will be worth about 5 RWHP over the factory lid.
To cut air box lid
