Code reader/scanner
Old Oct 16, 2005 | 05:55 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Default Code reader/scanner
As the title inplies, i'm looking to buy one. I'm looking at the AutoXray
AXY-2000. Summit has it for $189.95. Anybody have one of these?
or any advice as to which one to get. to be used on a 91L98
Old Oct 16, 2005 | 09:47 PM
SunCr's Avatar
SunCr
My Auto X-ray has been adequate and the only time I couldn't figure something out with it was when I had an intermittent connection on a MAP sensor. Took 3 dealers to solve that one out so I can't fault the scanner. I would check for a software upgrade after you buy it and I don't know if the current model comes with the necessary cable to hook it up to your PC (which you will need to do if there is an upgrade), but if it doesn't, I'd fork over the extra bucks for it.
