Sound from power booster??
Old Oct 16, 2005 | 07:14 PM
joseph p's Avatar
joseph p
Default Sound from power booster??
My '89 Coupe daily driver has developed a "squooshy" sound when you press on and off the brake lightly while parked. It may do it also while driving but I can't tell. It has a sound of pressure or air leaking while it's parked and if you tap the brake pedal on and off it produces this "squoosh" noise. The brakes work fine, it's not low on fluid, the pads are good. Could this be first indications that the booster is going?
Anyone experience this before?
Old Oct 16, 2005 | 07:51 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
When the booster on my 93 went out it made a wooshing sound but, more importantly, I could hardly push the pedal down it was so hard and could barely get the car to stop...
Old Oct 16, 2005 | 08:07 PM
johnnyevans's Avatar
johnnyevans
Booster is gone, replacement time.
Old Oct 16, 2005 | 08:17 PM
joseph p's Avatar
joseph p
Wow, Johneyvans, no questions asked...it's definitely the problem?
How long do you think I have?
Old Oct 16, 2005 | 08:26 PM
joseph p's Avatar
joseph p
While checking availability, I've noticed there is quite a difference between new OEM and new repro (twice the price)
Any thoughts?
Old Oct 16, 2005 | 08:43 PM
tigmaned's Avatar
tigmaned
check rockauto.com
Old Oct 16, 2005 | 08:46 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The booster is supposed to make some noise.
It draws air in from the footwell, and is pretty quiet unless you listen for it. If your brakes grab well, and the engine doesn't stumble when pressing the brakes, then it's fine.
Old Oct 16, 2005 | 08:49 PM
CentralCoaster
It draws air in from the footwell onto the backside of the diaphram, and is pretty quiet unless you listen for it, or push the brake pedal down quickly. If your brakes grab well, and the engine doesn't stumble when pressing the brakes, then it's fine.
A leaky booster will hiss continuously when the pedal is being used, or maybe only certain ranges of travel.
Old Oct 16, 2005 | 08:51 PM
vader86's Avatar
vader86
If the pedal begins to stiffen, its gone. Some hiss is normal, mine did it long before I replaced it.
Old Oct 16, 2005 | 10:03 PM
johnnyevans
I agree with Vader. The pedal movement will produce a little noise, but when you release the pedal or movement stops, you should hear nothing. The slight noise you hear is the chamber losing and gaining volume. I doubt you would even notice it.
If you're hearing the hiss, booster is going out, especially if it were loud enought for you to hear above the ordinary noise of the car.
If the vac check valve were split, you would have a hiss all the time and the pedal would give a bit more stiff from the vac leak. That's the plastic piece that pushes into the front side of the booster that the vac line pushes onto.
The 89 began hissing under light pedal pressure, pedal didn't stiffen on me, that's in the last stages of life, or a sudden failure. Pedal did begin to feel a little mushy tho'.
I bought my replacement about 3 years ago from Advance for around $140 or so. Don't even remember who made it, lifetime warranty. OEM will probably set you back twice that.
There's a steel replacement made, around the same funds as Advance, single diaphram like stock.
A dual diaphram is made, like the ZR1, it will give you more apply pressure with the same pedal pressure.
Life can vary from days to months, no way to tell.
If you want to check for sure, disconnect the vac line going to the booster and plug it temporarily. crank the car up and see if the hiss has gone away. I still say if you can hear it, it's bad.
Johnny
To Sound from power booster??
