what spool for Dana 44 ?
Old Oct 17, 2005 | 09:37 AM
corvette221's Avatar
corvette221
2nd Gear
Default what spool for Dana 44 ?
I have made the switch from a Dana 36 to a Dana 44, now I have broken the spiders in that. I have found out that a Corvette Dana 44 is not the same as a typical Dana 44. What spool or mini spool are available?
Old Oct 17, 2005 | 10:55 AM
jburnett's Avatar
jburnett
There is no spool readily available for the Dana 44 IRS... I've been modifying existing D44 spools to work in it though. However, if you're driving your car a lot on the street I would suggest an upgraded and cryo-treated posi-unit.
-Jeb
Old Oct 17, 2005 | 11:05 AM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
-Jeb
what upgrade would you recommend for the posi unit?
Old Oct 17, 2005 | 12:54 PM
ralph's Avatar
ralph
I have found the best combo is a stock GM (Spicer) posi that has been Cryo treated. Hardened spiders are a bomb looking for a place to explode.
Old Oct 17, 2005 | 03:04 PM
jburnett's Avatar
jburnett
As Ralph said, we've been cryo-treating them with no breakages thus far (I believe). Ralph had a set of the supposedly killer re-heat treated ones and they broke; I cryoed a set of stock Spicer ones for him and he hasn't broken them yet. The entire unit should be treated, that's the clutch packs, spiders, shims, cross-pin, and carrier case itself.
-Jeb
Old Oct 25, 2005 | 02:07 PM
red L98's Avatar
red L98
i got the spool from JEB
Old Oct 25, 2005 | 10:44 PM
NitrousSam's Avatar
NitrousSam
Default Car Creations
How much does a car creation dana 44 go for?
To what spool for Dana 44 ?
