F45 on 96
Old Oct 17, 2005 | 11:45 PM
MetalVette's Avatar
MetalVette
Default F45 on 96
Is the F45 ride selection suspension on a 96 the same as the early C-5's. I think I might need the shocks replaced and can't find replacement parts. Any help would be great.
Old Oct 18, 2005 | 12:16 PM
Z51L9889's Avatar
Z51L9889
The 96 and early C5's use the same basic ride control system but the shocks won't interchange because of the suspension differences between a C4 and C5.
Old Oct 18, 2005 | 12:35 PM
Gary04Z06's Avatar
Gary04Z06
Check http://www.vbandp.com/ for parts.
Old Oct 18, 2005 | 06:56 PM
96GS#007's Avatar
96GS#007
As someone mentioned, the shocks are not the same.
The only place to buy them is via a dealer. Make sure you're sitting down when they tell you the price...even from a place like Superior Chevrolet that sells 10% over their cost.
Old Oct 18, 2005 | 06:58 PM
cv67's Avatar
cv67
St. Jude Donor '05
www.eshocks.com
Old Oct 18, 2005 | 09:56 PM
Dan Parker '96's Avatar
Dan Parker '96
GM manages to screw us again (Delphi is GM owned). Zero rebuild support. Buy a new set at $1200. Thanks, GM jerks.
On the upside, a set of Bilstein Z51 shocks work terrifically and are reasonably priced.
Old Oct 18, 2005 | 10:43 PM
96GS#007's Avatar
96GS#007
"FYI", people often confuse the 1996 F45 Real Time Damping Delphi shocks with the '95 and earlier FX3 Selective Ride Control Bilstein shocks. The '96 shocks are not, let me repeat that, are not the same as the earlier shocks and they are not interchangeable.
As Dan mentioned above, you can punt them and substitute in traditonal shocks. I used to use Z51 Bilsteins and now have adjustable Koni Sports. There are various ways around the Service Ride Control light you'll get with the factory shocks removed from the system. Some pull the fuse in the rear compartment, I popped the light bulb out.
To F45 on 96
