Sometimes runs great, sometimes not
The first problem I found was a huge vacuum leak at the runner to intake manifold gasket (It had a lingenfelter superram plenum and runner with a 58mm throttle body). Basically I am just looking for stock performance so I removed the lingenfelter and replaced it with the stock plenum and runners.
It still didn't run very well so I asked some folks what I should try next. I was told that the 58mm throttle body was overkill for the stock plenum so I replaced it with a stock TB. It seemed to run better but still had a problem.
The problem is that at low RPM it will not idle smoothly and when I apply a little gas pedal it will bog and sometimes stall. I figured it was either a fuel problem or a spark problem. I set out to replace each component of both until I solved the problem. I replaced everything (plugs, wires, cap, rotor, coil, ignition module, fuel pump, fuel filter, fuel pressure regulator, EGR valve, TPS, etc.).
The problem is still there. One thing I noticed was that everytime I replaced something, the car would run good for a while. I then figured out that the problem could be corrected by disconnecting the negative battery cable. I then assumed that the problem was with the ECM. I replaced that but the problem still exists.
When I disconnect and then reconnect the battery, the problem seems to clear itself and the car runs great until I shut it off and restart it at a later time when it again will not run at low RPM. Any guess what it is?
2. Since you have changed about everything else - check:
Timing
o2 sensors - clean and no computer codes
fuel injectors - clean and operating properly
I did find some information about a couple of recalls for 85 vettes that may be contributing to the problem. I am going to take it to the dealer to see if one of them might be the problem. One is a problem with the coil and the other is a problem with the MAF sensor. I'll report what happens.
Mtrhd329, you may want to do a search online for 87 vette recalls.
