If the '93 uses quick connect fittings on the fuel lines, any of the Discounters (Pep Boys, NAPA, Kragen, etc) sell the tool you need to get them apart. Usually, you have to buy a set, but I don't remember it setting me back more than 10 bucks for the 4 or 5 that were different sizes and they're good for multiple applications.
At a Discounter, you never know what they might tell you - just look in the tool aisle. They're plastic semi-circles with a split tube so that they can fit over the line (black, white, gray & blue for the different sizes if I remember what I bought correctly). They can be used on a/c quick connect lines too and may be labled as such. Insert the size that fits into the fitting while pushing on the inlet side. Sometimes you'll hear a snap, but otherwise, with the tool fully seated, pull back to release. Real simple - just replace the o-rings before reinstalling (don't use the tool - just push the lines together). Trust you've got the fuel pressure relieved too???
even if I have the fuel rail off, shouldn't the pressure be gone?
Not nessessarily, if you didn't break the lines I'd say no.
Take off gas cap, press pin the shrader valve (kinda looks like tire stem) w/small screwdriver. That should work fine, you will get whatever gas is in the upper line come out but not much (1/4 cup maybe).
Wish all of my lines were set-up w/quick disconnects
thanksfor the help. Next step is to replace the head gaskets, waterpump and opti.Oh and clutch/flywheel... I'mseriosuly debating on pulling the engine out and replacing all seals... Meanwhile, give the engine and engine compartment a good steam bath....
