BUMP noise when taking off
I've checked everything I can think of underneath. Any ideas?
Someone makes a kit to reinforce it which solves the clunking but I can't put my finger on who sells it at the moment.
Vettedave
Vettedave: Beam plates, installed them when I did the bushings.
Kenwood and Togo: I've replaced the half sharft U joints about 30K ago and the drive shaft about 15K ago. Visually the ujoints all look good. I'd hate to think I only got 30K out of them.
At this point I guess I'll put her back up on the lift and tighten EVERYTHING and see what that does. Maybe I'll find something that doesn't look loose but is
Good Luck
If you let it go and get worse, you will feel the wobble at high speeds. the speed you notice it at will gradually get lower as the bushing wears more.
And, if you are totally stupid, it will get bad enough to rip the rear seal and start leaking tranny fluid until one day you will take a hard turn and uncover the tranny pump fuild pick-up. :o
I know you said that everythign seemed tight, but if the wheels were on the ground when you checked, the rear (connection to the Diff) of the shaft would have kept it from turning. Unless you were using a sizable cheater, you were probably not generating anywhere near the torque required to notice the play in the joint.
Recheck the slip-yoke bushing on the drive shaft, or you might join me in the " I bought a transmission because I was stupid" club.
Checked with it up in the air, I believe I saw enough movement to say the u joints look good. I'll have to check the d/s yoke.
Did you check the leaf spring for cracks on the left and right side of the center mount?
When you hear the clunk going foward stop the car and look at the top of the tire and see if it has a line on it from the wheel well.
I would also lift the car and use a rubber mallet and bang on the tires inside edge and outside edge and see if you can duplicate the noise.
Other wise I would say replace the rear end dampner drive shaft mounts.
I suppose that they could have been feeding me a line, but I have used them many times and they have proven trustworthy.
