Temperature Readout Confusion
Old Oct 20, 2005 | 01:30 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
Default Temperature Readout Confusion
I recently purchased an '85 4+3. After I have driven it long enough to reach normal operating temperature, I check the readouts. The oil says it's @ 235-240 degrees and the coolant still says "Lo."
Is this normal? What could be going on here?
Thanks!
-Kyle
Old Oct 20, 2005 | 02:04 PM
Hotred94's Avatar
Hotred94
If your oil temp is 235-240 then your coolant temp is likely about 220. The coolant readout says Lo until the engine reaches a minimum temp of 100. As I doubt your engine coolant is under 100 while your oil is 235, I would say check your temp sensor and wiring.
If you haven't been hot-footing it any to reach those oil temps, seems a tad bit warm to me. I run 190 water with 201 oil on a hot day (90 plus) just cruising. More agressive street driving brings water up to 210 and oil to 225. I do have some cooling mods but no coolers. Maybe you will want to check the whole cooling system out, clean out the rad, change fluids
Old Oct 20, 2005 | 02:06 PM
SunCr's Avatar
SunCr
Sounds like the temp sender is disconnected. Should be on the right head between #6 & #8, though for the '85, it may be on the left between #1 & #2. Find the wire and make sure it has a good connection to the sender. Test by grounding the wire against the block - gage should read 300 or so. If the the connection is good and the gage reads ok when the wire is grounded, you need a new sender. NAPA should have it.
Old Oct 20, 2005 | 02:31 PM
neat's Avatar
neat
Your car will run cooler because it's an LT1.
Another vote for disconnected sensor, or a bad sensor.
Old Oct 20, 2005 | 03:22 PM
williammackean
St. Jude Donor '07
Default Thanks!
Thanks for the help. I was initially told that the dash was bad, since the fan would still turn on. I suspected a sensor, but thought I'd be best to double-check.
I just bought this particular '85 with 65k. I already swapped out the Diehard for an Optima, replaced the fuel filter, new K&N air filter, and valve cover gaskets.
Here's my Minnesota Winter plan:
-Remove the hood (It's just easier!)
-Change every fluid & filter (Oil, trans, coolant)
-160 degree thermostat
-2.5" SST Manifold-back exhaust (Should I wrap the front y pipe?)
-Coil thru plugs tune-up (No MSD box)
-Test every sensor and replace as necessary
-Inspect and clean cooling system areas
-Replace broken antenna mast w/ Harada style and bypass switch
-Install adjustable fuel pressure regulator
-Possible chip replacement
-Troubleshoot why I don't always get hot air out of vents
While I have it all apart, is there anything else I should consider replacing? Any tips? Any simple ideas to increase HP/Torque? It looks like everything is original equipment on this. Anything I should look for? The future will be working on suspension, brakes & tires. For now, they're good enough. In time, I want to tastefully restore this vehicle to 'better than the original' performance without going overboard.
Thanks again!
-Kyle
A humble neophyte
Old Oct 20, 2005 | 04:10 PM
Togo's Avatar
Togo
heck, if you're gonna go the extra step and remove the hood, might as well just yank the motor out and replace it - i mean, the hood will already be off!
i would say to do the throttle body coolant bypass - but you are in a colder climate, it's probably best you leave it like it is.
how about an electric water pump to free up a few horses?
while you are into it - you might as well remove the radiator "cover" and see what garbage has made it's way in between the condensor and the radiator - this could be causing some of the high temps - as mentioned before, these C4s are magnificient garbage collectors - everything from cigarette butts to plastic grocery bags and everything in between!
other than that, i don't know exactly - you look like you are going way above and beyone what i did on my '85
Old Oct 20, 2005 | 04:20 PM
williammackean
St. Jude Donor '07
That's my grand future plan: Build a new engine and swap it out. We'll see if the wife lets me.
Electric water pump? I must be quite the fool, because I have not heard of this. Where would you suggest I look? I imagine that would require a change in the belts as well?
Old Oct 20, 2005 | 04:26 PM
Togo's Avatar
Togo
not exactly sure about where to find the pump - i think meizere (sp?) makes one, there is another manufacturer out there too - if you search this tech forum for waterpump, i'm sure you will undoubtedly find several posts about them.
also i just noticed - you plan on a 160 stat - you might get a lot of boos and hisses for this - the reasoning to keep stock temp tstat is to help boil off condensation in the oil to prevent the innards from rusting - and besides you are in minnesota - how hot does it actuall get there?
i'm in AZ - so my c4 has a 160 stat in it - and let me tell you - it gets HOTT here - and i'd rather be able to use my A/C in the summer rather than the winter so i'll stick with my 160.
but if i were you - i'd start with removing debris in front of the radiator to help lower those temps - and replace that coolant temp sensor to get an accurate reading.
To Temperature Readout Confusion
