Stock LT1 & LT4 head flow #??
Old Oct 21, 2005 | 08:18 AM
Paul Workman's Avatar
Paul Workman
Default Stock LT1 & LT4 head flow #??
Forgive me if this is often asked, but what are typical head cfm flow numbers for stock LT1 & LT4 heads, sans polishing, i.e., out of the box (assuming the same lift, e.g., .5 or .6)??
Thanks in advance. Great board!!
P.
Old Oct 21, 2005 | 04:55 PM
MYCoupe's Avatar
MYCoupe
Check these numbers out:
http://www.precisionporting.com/index_files/Page448.htm
Old Oct 21, 2005 | 05:09 PM
VenkmanP's Avatar
VenkmanP
http://www.chevyhiperformance.com/te...598/index.html
Old Oct 21, 2005 | 05:49 PM
sickspeedvette's Avatar
sickspeedvette
Originally Posted by Admiral94
It looks to me like the mighty LS1 heads with a stg 3 port job were out-flowed by the LT4's with the same.
Old Oct 21, 2005 | 06:48 PM
vader86's Avatar
vader86
There are several flow charts in links on my site.
Old Oct 21, 2005 | 08:06 PM
Paul Workman
Default Head flows
Thank you all very much. Very helpful!!!
P.
Old Oct 21, 2005 | 10:08 PM
Zix's Avatar
Zix
I find those numbers a little suspect to be honest, but beyond that the major advantage of the LS head is how the air is brought to the combustion chamber. In the GEN1 SBC heads there is a large bend in the intake tract to vacilitate the valve stem. In the LS heads it is a completely straight shot, which makes the airflow much more efficient, which is why the LS1/2/6 can make insane HP/TQ numbers with a simple heads/cam swap. There are LS2 heads and cam engines out now that make close to 500RWHP, that number is barely attainable on some of the best put together radical cammed L98/LTx 383/396+ stroker motors.
Old Oct 21, 2005 | 10:39 PM
vader86's Avatar
vader86
Youre not comparing apples to apples when you look at LS vs LT heads, valve angle is different.
To Stock LT1 & LT4 head flow #??
