Confusing FI question
Old Oct 21, 2005 | 03:56 PM
neat's Avatar
neat
Default Confusing FI question
I ask this question about once a year, and never seem to get any real answers. It's due again, so here we go.
Is boost based on displacement or head flow?
On a 350, do I start to build boost once I move more than 350 cubic inches of air per rotation of the engine, or do I see positive intake pressure prior to that because the restriction is the heads? Which is it, heads or displacement?
Old Oct 21, 2005 | 04:12 PM
Morley's Avatar
Morley
You start to build boost once you put more air into your cylinders than they are capable of drawing in without forced induction.
Old Oct 21, 2005 | 04:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
OK, the question is what pressure would you see if you ran a blower that emptied into the air not into the engine intake??
Clearly it would take some pressure greater than 1 atmosphere to even pump air in this manner, right. So I think the pressure comes from the fact that pressur must be generated in order to move any fluid. If there is no fluid motion there would still be pressure; pressure would only drop if the blower no longer had the capacity to deliver the VOLUME of air needed.
So a blower must be sized to meet the engine's requirements so that it can deliver the rated pressure in the volume needed by the motor.
Old Oct 21, 2005 | 07:46 PM
CFI-EFI's Avatar
CFI-EFI
Plus it takes two engine revolutions for a 350 CID engine to pump 350 CID of air.
RACE ON!!!
To Confusing FI question
