93 stops running will not restart code15
Old Oct 23, 2005 | 02:10 PM
megawatt220's Avatar
megawatt220
Default 93 stops running will not restart code15
I have a 93 lt1 installed new temp sensor no help, hard starting and back fireing any help would be deeply appreciated thanks Tim
Old Oct 23, 2005 | 02:31 PM
bogus's Avatar
bogus
Code 15? Coolant temp low?
Which temp sensor did you replace? The one on the waterpump or the one on the right head?
The waterpump sensor feeds the ECM and the digital display. The head sensor feeds only the analog gauge.
Check to be sure that the harness to the waterpump temp sensor is ok. It can get caught in the belt and become cut up and stuff.
Old Oct 23, 2005 | 02:43 PM
megawatt220
Yes I replaced the one on the water pump and the wires seem ok I get 5 volts acrose the sensor harnes
Old Oct 23, 2005 | 04:46 PM
bogus's Avatar
bogus
hm. odd.
Read this:
C4 Guru - Code Reading 1992/1993
Old Oct 23, 2005 | 08:04 PM
megawatt220
Thanks bogus I printed all the info you sent and will go through it and let you know how it works out Tim
Old Oct 24, 2005 | 01:26 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
15 definately will cause these problems>> I'm thinking you have a short in your electrical connector. I would reccomend getting a service manual and run thew the diagnostic flow charts.
Old Oct 24, 2005 | 08:26 AM
luvmy92's Avatar
luvmy92
Had the same problem and replaced the sensor in the waterpump, and that still didn't do it. Turned out it was the pigtail connector itself that needed replacing.
Mike
Old Oct 24, 2005 | 08:33 AM
Tom Piper's Avatar
Tom Piper
Is that reading of 5 volts what you are getting at the harness with the sensor plugged in or unplugged?
You should not have 5 volts with the sensor plugged in.
If you do have 5 volts with the sensor plugged in, either the sensor is open or the connector isn't making contact.
Tom Piper
Old Oct 24, 2005 | 10:43 AM
megawatt220
that was with the sensor unpluged
Old Oct 24, 2005 | 12:03 PM
Tom Piper's Avatar
Tom Piper
Then, my guess is you have a damaged connector and it isn't making contact with the sensor or the sensor is defective.
The way to test it is to check the voltage with the sensor plugged in -- it should be less than 5 volts.
Tom Piper
Old Oct 24, 2005 | 01:33 PM
megawatt220
Yes i get 4.87 with it pluged in. also had the same problem a year ago when i bought the car in tampa going back to chicago had the sensor replaced and ok till now.
Old Oct 24, 2005 | 02:44 PM
Tom Piper's Avatar
Tom Piper
I would have expected it to be lower than even 4.87 volts.
If you just turn the key on without the engine running, what is the temperature showing on your digital engine coolant temperature readout?
And, does it seem like it is the correct temperature?
Tom Piper
Old Oct 24, 2005 | 06:00 PM
megawatt220
I put one more new temp. sensor and it is working fine Thanks for the help Tim
To 93 stops running will not restart code15
