Which optispark to use
Regards, Greg
The Dynaspark has a serious amount of silicon used on anything that might leak basically waterproof.I feel safe washing my engine now and do it when necessary.
Regards, Greg
The first-generation, passively vented (had only weep holes to drain moisture out) Opti was used on Corvettes from '92 thru '94. The second-generation, actively vented (used intake vacuum to draw filtered air through the unit to draw out moisture) Opti was used on Corvettes from '95 thru '96. The Opti disappeared entirely from Corvettes (in favor of a DIS system) with the introduction of the LS1 engine in '97.
The active-venting on the second-gen Opti was intended only to remove small amounts of condensed moisture. If the car won't run because the Opti has been douched and is loaded with wet stuff, the active venting is of little use. I've heard of one guy who hooked up an aquarium air pump to his second-gen Opti's vacuum hoses and used it to force air through the unit for quite some time, and he reported that he got it dry enough to run again, but I can't vouch for this.
Best bet by far is to avoid getting any moisture inside of the unit to begin with, and the best way I know of to prevent it from happening (in a '92 - '94 Corvette in particular) is to switch to a DynaSpark unit.
Be well,
SJW
The second-generation, actively-vented Opti was GM's only attempt to revise and improve the design of this assembly. It was a significant improvement over the first-gen, passively-vented Opti, but still had some serious design weaknesses.
The DynaSpark was designed by an aftermarket business, and they started by listing every deficiency they could identify in the OEM units' designs, and then set about solving each of the problems. The billet aluminum housing alone is a big step forward, and DynoTech also eliminated one of the two enclosure seals entirely, thus deleting one of the possible sources of leakage. DynoTech did everything possible to ensure watertightness in the DynaSpark, including sealing the low-voltage connector, which was a key problem area with the OEM Optis. I would be very surprised to hear that even one in a thousand DynaSpark units ever got wet inside. When I spoke with Phil at DynoTech, he actually encouraged me to hose down the DynaSpark once it was installed on my engine -- that says a lot to me about how confident he is in its watertightness.
I did quite a bit of research into the various options that were available to me when my OEM Opti (first-gen) failed at 19K miles. I did a lot of digging on the 'Net, and spent time on the phone with Pete at Delteq (Pete is a great guy, BTW), and with Phil at DynoTech and I concluded that the improvements provided by the DynaSpark are numerous.
I've done a fair amount of mechanical design work in my career, and I'm not easily impressed. But I was quite impressed when I removed the DynaSpark from its box and examined it closely. Phil was really using his head when he designed this thing. It appears to be very well designed, and very carefully fabricated and assembled. Check out DynoTech's website for more details on all of the improvements versus the OEM stuff. It's worth the time spent reading all of this, IMHO.
Be aware of one thing: DynoTech is adamant that you follow their installation instructions EXACTLY when installing this unit, and you should do exactly as they say. Especially if your engine has been modified with non-original camshaft, timing gear, etc, there are measurements that must be made, etc, to ensure that the longevity of the DynaSpark is not compromised.
I was tempted by the Delteq system, as it offered the tantalizing possibility that I might be able to leave my existing Opti/water pump, etc in place, which was a most tempting option, indeed. But, I finally concluded that I simply had zero confidence that I could rely on the optical section of my OEM Opti to continue to provide good data to the ECM for any length of time (and I'm glad I decided this way, as the OEM Opti showed signs of rust around its bearing upon inspection after I yanked it off of the engine).
I also decided that I really wasn't very excited about adding the Delteq system to the already-too-cluttered engine bay in this car. Plus, with the Delteq, I'd have had to either hack my tach filter out of my underhood wiring harness and bypass it electrically, or add an MSD tach amplifier to the setup, or my tach would no longer work -- I don't think this is an issue for all LT1/LT4 Corvettes, but it was an issue on my '94.
The LTCC system was not yet available to buy, and it would have required adding eight coilpacks (rather than the four used in the Delteq system), so it was not an option. Given what I've learned about the LTCC and Delteq systems, I would choose the Delteq over the LTCC without hesitation, if I were to eventually decide to convert the high-voltage section of my ignition system to a Distributorless Ignition System.
So I finally settled on the DynaSpark. And I have no regrets. It was a direct, bolt-in swap for the OEM Opti. The only additional changes required were to rob the low-voltage connector housing from my OEM Opti wiring harness and add it to the DynaSpark's harness (no big deal, as a pin extractor tool is furnished with the DynaSpark unit), and I had to add a (not-furnished) vacuum tee to an existing vacuum hose on the engine, and add a hole in my intake bellows to receive the other vacuum fitting. It all went together very nicely, and preserved the nearly-stock appearance under the hood, for what that's worth. The car has run beautifully since I did the job last year (~10k miles, now).
Be well,
SJW
And there's never an easier time to replace the plug wires than when you're already up to your armpits in the front end of the engine doing the Opti and w/p. The wires are a real PITA to replace, but it's significantly easier to do when you're already into it this deep, as you'll have improved access to the wires where they connect to the Opti.
Be well,
SJW
Greg
Greg
There is the issue of ozone generated by the coil spark inside the opti also and over time it can be corrosive especially on Gen I optis.
Then there is the carbon tracing effect on the inside of the cap it is a good conductor and spark will follow the path of least resistance sometimes along the carbon trace.This is the failure that throws no codes but runs like crap.
